Devo 6/8 supplemental toggles
- Khan
- Build. Crash. Repeat.
11 Jan 2017 10:11 - 11 Jan 2017 10:17 #57808
by Khan
Devo 6/8 supplemental toggles was created by Khan
Hi guys !
I made a few toggle icons for use with my multicopters, let me share them :
In order, we have :
www.banggood.com/STAR-POWER-Radio-Contro...ba-JR-p-1021926.html
I've attached the .psd (photoshop) file in the zip, feel free to use it to modify or make new icons.
In order, we have :
- Throttle Hold : On/off
- Lights : Off/on
- Flight Mode : Angle/Horizon/Acro/Airmode
- Buzzer : On/off
Last edit: 11 Jan 2017 10:17 by Khan. Reason: added pics in the topic
- Deal57
26 May 2017 14:44 #62565
by Deal57
Replied by Deal57 on topic Devo 6/8 supplemental toggles
Nice! I liked these so I put them into one big file for the color transmitters. I've cleaned up some of the older toggles to add transparency. Rename this to Toggle3.bmp to use.
It appears the 5.0 version can only find 64 icons in a color Toggle3 file. When you have more, you can see the first 64 then it starts over from the first ones. So if there is something I should add or replace
- Khan
09 Feb 2019 21:58 #72839
by Khan
Replied by Khan on topic Devo 6/8 supplemental toggles
I updated my toggles with new functions that I needed for Betaflight/Inav :
I replaced the bulb with a more modern LED chip, and added :
And here's the Photoshop file :
- Turtle mode: on/off
- Blackbox: record/pause/erase1/erase2
- Servo autotrim: inactive/active
- GPS Home coordinates: set/erase
Attachment not found
Time to create page: 0.062 seconds
Custom Skins
- Devo 6/8 supplemental toggles
