VM dedicated to compiling Deviation
09 May 2013 07:22 #9730 by Wene001
Replied by Wene001 on topic VM dedicated to compiling Deviation
tried to flash my devo12s with fresh code but something is wrong with the script i think.
the complete text is missing on the screen after powering up the tx.
i noticed that the devo12_lib.dfu is now 897KB
before changing the deviation script it was 1441KB
tested with PBs and RBEs repo
09 May 2013 09:09 #9733 by sbstnp
Replied by sbstnp on topic VM dedicated to compiling Deviation
Wene001 wrote: tried to flash my devo12s with fresh code but something is wrong with the script i think.
Just tested, my generated LIB has 1441KB. Cannot test further as I don't have a devo12
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
09 May 2013 09:20 - 09 May 2013 09:21 #9734 by sbstnp
I just fixed a bug, please do
deviation self-update
And try again.
Devo 10 + 4in1
Spektrum Dx9
Last edit: 09 May 2013 09:21 by sbstnp.
09 May 2013 11:17 #9738 by Wene001
Works like a charm
Thanx
15 May 2013 06:16 #10001 by Wene001
Today i tried to compile from RBEs Repo for my Devo 12
i get the message:
+ checking string list length for devo8
make: *** [filesystem/devo8/models/model30.ini] Error 1
<< Error compiling sources, aborting.
I tried:
Deleting local repo
deviation setup
hg pull
hg update
Nothing helps
Thanks for your help :-)
  • rbe2012
  • rbe2012's Avatar
15 May 2013 07:13 #10005 by rbe2012
Replied by rbe2012 on topic VM dedicated to compiling Deviation
Hello Wene,
as you will have expected I have no problems compiling from my repo ;) I get this message too but this is because I write protected some of the ini-files so make can not write them.
The error message is a little bit misleading. For some reason make tells about "[filesystem/devo8/models/model30.ini]" if anything in a greater block of code goes wrong. PB has implemented the note with the string length so we can differentiate between problems while creating the file system and such concerning the strings.
The string list length checking is important to make sure that the resources are not over-provisioned (needed for the translation table). It is possible that I have used more strings in the last code changes so the limit is exceeded.
I will take a look in the evening. But I would assume the error is caused by my code rather than by the build machine.
15 May 2013 07:27 #10006 by sbstnp
Will look into it when I have some free time (at work atm).
Devo 10 + 4in1
Spektrum Dx9
  • rbe2012
  • rbe2012's Avatar
15 May 2013 08:32 - 15 May 2013 08:33 #10010 by rbe2012
What I thought: I have ignored the error message because I get it every time build a new version (and I do this dozens times a day...). But my code uses 321 strings which shall be translated while only 320 are allowed.
If you want to workaround: in src/config/language.c line 33 the value of '#define MAX_STRINGS 320' to a higher value (321 should suffice) and compile again. I tested it out - it will not have side effects.
I filed an issue at bitbucket for this and will fix it in the evening.
EDIT: sbstnp, I just have seen your message. Nothing to do for you.
Last edit: 15 May 2013 08:33 by rbe2012.
15 May 2013 09:55 #10012 by sbstnp
No problem :)
Devo 10 + 4in1
Spektrum Dx9
  • rbe2012
  • rbe2012's Avatar
15 May 2013 16:39 #10033 by rbe2012
I increased the number of strings to 330. It compiles now without ANY error :whistle:
devo8                              :   321 lines
filesystem/devo8                   :   321 lines
Total                              :   321 lines
Allocated                          :   330 lines
31 May 2013 02:44 #10452 by MacC
Replied by MacC on topic VM dedicated to compiling Deviation
Hi, I am a newbie in this forum. Now I met problem to download VM machine (.OVA). It was stopped while around 2M Bytes. Where can I get it except the original web address? Or I did something wrong? Thanks
31 May 2013 03:47 #10453 by sbstnp
No reason why it shouldn't work. The host has pretty good speed too. I say try again and if you still have problems I'll figure out a way to host it someplace else as well.
MacC wrote: Hi, I am a newbie in this forum. Now I met problem to download VM machine (.OVA). It was stopped while around 2M Bytes. Where can I get it except the original web address? Or I did something wrong? Thanks
Devo 10 + 4in1
Spektrum Dx9
31 May 2013 05:43 #10455 by MacC
Hi sbstnp, Thanks for helping. I try many times and get same problem. I have tryed both IE and Chrome to download but both failed. I also try to turn the proxy off but same. Is there another way to download it? Thanks
31 May 2013 07:35 - 31 May 2013 08:07 #10457 by sbstnp
No, not yet sorry. I'm sure it's not a problem with my host, since I've been able to download it from my hotel room and it worked.
Tonight I have a flight back home and over the weekend I'll try to find a solution for you.
MacC wrote: Hi sbstnp, Thanks for helping. I try many times and get same problem. I have tryed both IE and Chrome to download but both failed. I also try to turn the proxy off but same. Is there another way to download it? Thanks
Devo 10 + 4in1
Spektrum Dx9
Last edit: 31 May 2013 08:07 by sbstnp.
31 May 2013 08:01 #10458 by MacC
Well noted, Thanks.
31 May 2013 11:42 #10462 by MacC
Thanks for sbntnp kindly helping. It is working now. I have got it finally.
31 May 2013 12:47 #10463 by sbstnp
Happy to hear it:)
MacC wrote: Thanks for sbntnp kindly helping. It is working now. I have got it finally.
Devo 10 + 4in1
Spektrum Dx9
20 Jun 2013 19:34 - 20 Jun 2013 19:35 #11171 by adabman
Replied by adabman on topic VM dedicated to compiling Deviation
Hello, I just got the vm working in hyper-v, my preference. I am able to build successfully. So far I have built the reg deviation, PB's new-gui, and RBE's Devo 12 widescreen build.
Problem in all cases when I flash the Devo12:
Seems there is fonts problem.. Any ideas?
Deviation :) 1 TX to rule them all...
Last edit: 20 Jun 2013 19:35 by adabman.
  • rbe2012
  • rbe2012's Avatar
20 Jun 2013 19:37 #11172 by rbe2012
You must flash the library too (devo12-lib.dfu, in the library tab of dfuse). It contains the fonts and more.
20 Jun 2013 19:47 #11173 by adabman
Sorry should have said, I did flash the lib-devo12 also. as well tried flashing the lib included in the filesystem.zip "devo12-lib.dfu"
Same prob :(
Time to create page: 0.398 seconds
