Add two switches to the Devo 7e
17 Nov 2015 21:01 #40166 by BobbyC
Replied by BobbyC on topic Add two switches to the Devo 7e
Do you have a wire connecting the 2 center pins on the switches?
18 Nov 2015 07:38 #40179 by saidem
Replied by saidem on topic Add two switches to the Devo 7e
Yes, see photographs and diagram on page 1!
26 Nov 2015 12:45 #40402 by saidem
I wonder if the modification works with 1N4003 diodes?
Thank-you.
26 Nov 2015 15:44 #40405 by BobbyC
I used 1n4004 diodes (slightly higher voltage rating) and it works fine but the 1n4148 is a better choice.
26 Nov 2015 16:32 #40407 by saidem
Ok, so I think it must be good because the 1N4003 has a lower reverse voltage.
Thank-you ;)
25 Feb 2016 19:56 #43643 by dabrain
Replied by dabrain on topic Add two switches to the Devo 7e
I just did the 3x2 switch mod.
Tried to modified modify the "hardware.ini" to "extra-switches=3x2" with notepad++,
but I don't see the new switches when i checked in Tranmitter menu-> Channel Monitro->Stick inputs.
I'm on the deviation-devo7e-v4.0.1-4fc5268 nightly.
I added the hardware.ini, hope someone can help, i really want to mod my tx succesfully. :(
25 Feb 2016 20:23 #43644 by gdenton
Replied by gdenton on topic Add two switches to the Devo 7e
Remove the semi-colon, should be:
extra-switches=3x2
not:
;extra-switches=3x2
25 Feb 2016 20:25 #43645 by Arakon
Replied by Arakon on topic Add two switches to the Devo 7e
Remove the semicolon in front of the switch line. It means that the line is commented out and not active.
25 Feb 2016 21:48 #43647 by dabrain
I did try to remove the semicolon, but it makes no diffirent, the switches are still not visible.
what am I missing :S
25 Feb 2016 21:53 #43648 by BobbyC
You need to configure the switches in the modelx.ini files.
[channel5]
failsafe=125
template=complex
[mixer]
src=SW A0
dest=Ch5
switch=SW A0
scalar=-125
curvetype=fixed
[mixer]
src=SW A0
dest=Ch5
switch=SW A1
scalar=0
curvetype=fixed
[mixer]
src=SW A0
dest=Ch5
switch=SW A2
scalar=125
curvetype=fixed
[channel6]
failsafe=125
template=complex
[mixer]
src=SW B0
dest=Ch6
switch=SW B0
scalar=-125
curvetype=fixed
[mixer]
src=SW B0
dest=Ch6
switch=SW B1
scalar=0
curvetype=fixed
[mixer]
src=SW B0
dest=Ch6
switch=SW B2
scalar=125
curvetype=fixed
25 Feb 2016 22:03 - 25 Feb 2016 22:03 #43649 by gdenton
Tranmitter menu-> Channel Monitor->Stick input, then press lower left DN- button 4 times and then you should see SW A0, SW A1, SW A2, SW B0, SW B1, SW B2.
Last edit: 25 Feb 2016 22:03 by gdenton.
25 Feb 2016 22:50 #43651 by dabrain
@gdenton I was already looking there, but there are no switches.
Do I realy have to configure the modelx.ini? Will try that tomorrow
27 Feb 2016 08:54 #43757 by dabrain
I was not Able to find the model x.ini. Is it required to change it to let the switch mod work? Should i change the nightly to another version? Maby that works for my switch mod? I now use the latest.
27 Feb 2016 13:00 #43770 by Deal57
Replied by Deal57 on topic Add two switches to the Devo 7e
The latest is correct. In my experience you do not have to modify the modelx.ini to see the switches. If you have the installed the switches correctly, and have removed the semicolon from the hardware.ini line, you can see them in the stick input screen. If that isn't working they are either not installed correctly or the hardware.ini file is wrong.
So can you please post your hardware.ini as installed now? Also, if you open up your transmitter, try to get good closeup photos of the wiring or switches and post them.
29 Feb 2016 19:32 #43894 by dabrain
I've added pictures of my soldering, hope it's close up enough. I also added my hardware.ini as installed now. And I added a movie so you can see what's my tx showing. Hope you guys can help, really frustrating :sick:
For some reason i cannot upload any picture so I added links to the picture and the movie:
goo.gl/photos/BoRmegZFuLpSt1R98
goo.gl/photos/L9jEZR6wqSc5vR7J9
goo.gl/photos/rARXQeYctmkhbjC19
29 Feb 2016 19:51 - 29 Feb 2016 19:53 #43898 by TomPeer
Replied by TomPeer on topic Add two switches to the Devo 7e
Hardware.ine should be:
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
extra-switches=3x2
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A1
Last edit: 29 Feb 2016 19:53 by TomPeer.
01 Mar 2016 13:41 #43950 by dabrain
Damn, yes I know i have to remove the semicolon before extra-switches=3x2.
Now I'm confused, really don't know why there's a semi colon in this hardware Ini (I'm sure i deleted it;))
Will try to change this tonight
@TomPeer For sure I will copy your comment right into my hardware ini
Thx
03 Mar 2016 18:10 #44033 by dabrain
Thankyou everyone for your help.
copyed your harfware.ini TomPeerand it worked now. i'm so happy :woohoo:
13 Mar 2016 19:19 #44515 by arkennedy75
Replied by arkennedy75 on topic Add two switches to the Devo 7e
OK, I search around but no luck. Sorry for the noob question.
How to install the "nightly builds"? I don't see a .dfu to use with the Upgrade Tool. I see the .exe file in the Nightly Build but I'm unsure what to do with it.
Thanks for the help.
13 Mar 2016 19:50 #44518 by Arakon
If you have an .exe, you downloaded the emulator, not the actual transmitter firmware.
Download the one without "emu" in the name.
Time to create page: 0.237 seconds
