Add two switches to the Devo 7e
- Seven5555
21 May 2016 12:13 #48947
by Seven5555
on the side of the switch it says "ON ON ON" then below it "0.4 VA MAX" on the the other side it says "7211" "C&K" 'USA"
Something tells me that these aren't gonna work. Thank you for helping me. I appreciate it very much. I'm learning a lot fast.
Replied by Seven5555 on topic Add two switches to the Devo 7e
silpstream wrote: You have a 6 pin switch. Can you check that it is a on-off-on switch and no a on-on-on switch?
- silpstream
21 May 2016 12:35 #48948
by silpstream
They can work. You need to wire it in a on-off-on configuration. Try this:
I've not attempted it, but it should solve your problem. Note that the center pins are connected to each other. Do it exactly the same for both switches (as in DO NOT mirror it). Good luck!
Replied by silpstream on topic Add two switches to the Devo 7e
Seven5555 wrote: Something tells me that these aren't gonna work.
- Seven5555
21 May 2016 16:39 #48956
by Seven5555
Anything you want to eat, anything,....its just going to look and taste like pretzels.lol jl/k
That did it. Thank you very very much. its not pretty in there but it works. Is there a way to put a one way spring type toggle? I'm trying to configure this to a 350 QX...
Wait, I'm still celebrating these switches!! I am so glad. I was really stumped. the way those switches look on the inside, i just figured they poles were parallel.
Thanks again
Dean
Thanks again
Dean
- silpstream
21 May 2016 17:14 - 21 May 2016 17:31 #48958
by silpstream
Glad it worked!
There are ways to wire in a momentary switch. The easiest is probably to tap one of the trims or buttons. The trims and buttons can be assigned to a virtual channel to give you what you want.
Try using them first and if you need, you can wire a switch in parallel to a button or trim to activate it.
A more complex method would require you to do the ultimate7e upgrade to 6 switches, but it requires a processor change. Not for the faint of heart.
Get used to the tx first, then decide what you want to do. You'll find a lot of good info and people in the forums for help. Have fun!
Last edit: 21 May 2016 17:31 by silpstream.
- ahlod
05 Jul 2016 12:07 #51313
by ahlod
Replied by ahlod on topic Add two switches to the Devo 7e
Hi Guys,
I am doing this mod soon and I am ordering parts will this switch work for the Devo7e?
goo.gl/mfHck9
goo.gl/mfHck9
- silpstream
05 Jul 2016 16:49 - 05 Jul 2016 16:50 #51319
by silpstream
@ahlod, those will work fine.
Last edit: 05 Jul 2016 16:50 by silpstream.
- ahlod
06 Jul 2016 08:13 #51353
by ahlod
thanks man!silpstream wrote: @ahlod, those will work fine.
- naude
15 Oct 2016 08:29 #54951
by naude
Replied by naude on topic Add two switches to the Devo 7e
Possible to use 1n5000 diode?
- Ktrudell
10 Nov 2016 01:45 #55828
by Ktrudell
Replied by Ktrudell on topic Add two switches to the Devo 7e
I just got done with this mod and went into the hardware ini and put 3x2 and I get nothing on the tx. Have 5.0 what am I missing here
- DaveyP
10 Nov 2016 14:06 #55837
by DaveyP
Its possible.. but over kill
It can do no harm to try it
Replied by DaveyP on topic Add two switches to the Devo 7e
naude wrote: Possible to use 1n5000 diode?
- DaveyP
10 Nov 2016 14:16 #55838
by DaveyP
Check your wiring,then check your wiring again, check the diodes direction...
If that fails then
Post piccys of your wiring and your hardware.ini
Ktrudell wrote: I just got done with this mod and went into the hardware ini and put 3x2 and I get nothing on the tx. Have 5.0 what am I missing here
If that fails then
- Ktrudell
10 Nov 2016 16:46 #55839
by Ktrudell
Do i have ti have nightly version install. I just have the non nightly 5.0. This is how my wiring is set up.
- DaveyP
10 Nov 2016 19:23 #55842
by DaveyP
Wiring and diodes look fine to me...
If the hardware.ini had the switches mentioned then that should be fine
Soooooo copy and paste of your hardware.ini (I take it that the hardware.ini you edited was already on your 7e and hasn't just been added)
- Ktrudell
10 Nov 2016 22:37 #55844
by Ktrudell
Pic of hardware file
- DaveyP
11 Nov 2016 00:06 #55846
by DaveyP
Every thing you have done looks great
So just to check what your looking at on your devo 7e, have a look at this video from 58:30 onwards
- Ktrudell
11 Nov 2016 00:56 #55847
by Ktrudell
My actual remote.
- Ktrudell
11 Nov 2016 01:00 #55848
by Ktrudell
Plus my hardware ini was initially all a straight line. I made it that way ti take pictures. And it just says hardware when I click on it nit hardware ini
- Ktrudell
11 Nov 2016 01:11 #55849
by Ktrudell
Screen display
- RoGuE_StreaK
11 Nov 2016 04:25 #55851
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Add two switches to the Devo 7e
El Ghetto, and probably not exactly what you are after, but chuck a rubber band on the switch, wrap it over the TX handle, then back to the switch; this will hold the switch back in the top position, and when you pull it it will return after release. Quick'ndirty, and you can remove if you want to go back to using it as a normal switch. I'm using this for "launch" mode for my DLG.Seven5555 wrote: Is there a way to put a one way spring type toggle? I'm trying to configure this to a 350 QX...
- HappyHarry
11 Nov 2016 14:25 #55854
by HappyHarry
Replied by HappyHarry on topic Add two switches to the Devo 7e
only edit the hardware.ini with something like notepad++ >>
notepad-plus-plus.org/download/v7.2.html
as the windows editors corrupt the files
Time to create page: 0.116 seconds
