How to replace stick pots
06 Mar 2013 04:57 #7409 by vlad_vy
How to replace stick pots was created by vlad_vy
If you have problem with Walkera stick pots, you can do quick repair. The same potentiometers used in some servo, e.g. Spektrum DS821 or JR ES539.
Attachment SpektrumDS821.jpg not found
Attachment SpektrumDS821-1.jpg not found
Also, the same pots used at JR transmitters (JR 9303, DSX9)
06 Mar 2013 05:00 - 06 Mar 2013 05:36 #7410 by cmpang
Replied by cmpang on topic How to replace stick pots
thanks for the into.. is it that you find some problem in your Walkera stick?
Last edit: 06 Mar 2013 05:36 by cmpang.
06 Mar 2013 05:05 - 06 Mar 2013 05:10 #7411 by vlad_vy
Replied by vlad_vy on topic How to replace stick pots
Not me, but one user at russian forum had problem with one pot in his new Devo 12s. After my tip about servo pots, he successfully replaced potentiometer, calibrate sticks and Tx works. He used pot from JR ES539 servo (5.3kOhm).
Last edit: 06 Mar 2013 05:10 by vlad_vy.
19 Jan 2014 14:37 - 26 Jan 2014 13:13 #18678 by matrixFLYER
Replied by matrixFLYER on topic How to replace stick pots
Are the pot in DEVO 10 the same? My pot aren't precise! I need to replace them!
Can I find these pot somewhere else?
Some images of the potentiometers of the Devo 10:
www.dropbox.com/s/m7rpsw4yp9epdq1/IMG_20140125_233935.jpg
www.dropbox.com/s/nrae5vrk4k6ek2v/IMG_20140125_233943.jpg
Last edit: 26 Jan 2014 13:13 by matrixFLYER.
16 Apr 2016 18:57 #46641 by fredskidoo
Replied by fredskidoo on topic How to replace stick pots
matrixFLYER wrote: Are the pot in DEVO 10 the same? My pot aren't precise! I need to replace them!
Did you ever locate replacements matrixflyer?
Time to create page: 0.154 seconds
