Dual rates
07 Apr 2013 01:05 #8665 by markosgt
Dual rates was created by markosgt
Hello everyone.
I just installed the deviation firmware in my devo8s because im waiting
my blade 130x to arrive.
Problem is tha i try to setup my minicp and i cant make the tail fast as i had it in th original firmware. I cant find how to setup the dual rates.
Can someone explain me without giving me a ini file?
thank you in advance.
07 Apr 2013 14:41 #8688 by markosgt
Replied by markosgt on topic Dual rates
Forgot to mention that im in advanced mode.
07 Apr 2013 15:50 - 07 Apr 2013 15:51 #8689 by sbstnp
Replied by sbstnp on topic Dual rates
This procedure is very nicely outlined in the user manual.
Devo6/8/12:
deviationtx.com/repository/Documentation...ationUserManual.pdf/
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 07 Apr 2013 15:51 by sbstnp.
07 Apr 2013 18:12 #8694 by markosgt
Yes you are right. Although i read all the manual i wasnt carefull enough to see it. Thank you though cause i was sure i didnt see it in the manual and if you wouldnt tell me i wouldnt read it through again.
Thanks.
This firmware is perfect.
Thanks to the deviation group too.
Time to create page: 0.105 seconds
