use WK-CTL01-D with deviation on Devo10
- Tschosef
31 Jan 2014 09:31 #19481
by Tschosef
use WK-CTL01-D with deviation on Devo10 was created by Tschosef
i have a question. I am sitting here since some hours, and searching the info, how to connect the Telemetry Module WK-CTL01-D to the devation Devo 10
Do you have a idea?
i am using fixed id and i was already able to bind the Devo10 to the RX1002
But now, the telemetry module is still blinkng, and no values are shown in telemetry monitor.
Hope for your help
best regards
Tschosef
Do you have a idea?
Hope for your help
best regards
Tschosef
31 Jan 2014 09:43 #19483
Replied by FDR on topic use WK-CTL01-D with deviation on Devo10
You have to bind the rx and the telemetry module at once.
So clear the fixed id from the rx, autobind both, and send the fixed id to both after that...
- Tschosef
31 Jan 2014 15:34 #19494
by Tschosef
Replied by Tschosef on topic use WK-CTL01-D with deviation on Devo10
Thank you verry much.
do you have a idea, how to bind the Telemetry module with a fixed id ??
I have got no Manual to the module...
in auto binding mode i was able to use it, but i need fixed id Binding, because in Failsafe Situation the gps copter is flying to home. But if signal is back, i hav controll again.
In auto binding mode, i never will get the connection again
Best greets
Erich
Best greets
Erich
31 Jan 2014 18:39 #19520
Simply when both the rx and the telemetry unit are bound automatically, set a fixed id, and send to them: it will be sent to both, and both will bound to that same fixed id...
- Tschosef
31 Jan 2014 21:14 #19529
by Tschosef
Hello...
thank you, i got it.
My problem was, i had to delete the fixed ID of the Receifer first
after that i was able to bind both in automatic mode, and then enter a ID Number...
thank you, it works, and it is great !! Copter Akku Voltage in Display and Alarm... now i am able to remove the lipo beeper
Time to create page: 0.198 seconds
