How to load an F12E with Deviation(Possibly F7)
30 Aug 2017 06:51 #64029 by RubenRC
planetfpv wrote: So I found a thread suggesting to also read the devo f4 thread and got a lot of help from that. On my devo f7 I was able to get dsmx and dsmx and devo protocols. I ordered my 4 in 1 so I can use my frsky receivers.
The video works great when I flew my blade fpv nano. I set my aux 2 to activate the video. At some point I accidently set my throttle to start video so I had to hold full stick to fix it.
Dsmx and dsm2 binding was very and my blade nano flew great. My cheerson cx10 dsm2 flew fine and didn't notice any issues either.
Hey Planetfpv what did you do to get dsmx to work? I have the protocol enabled and I can bind but the controls are all wrong even when I check betaflight it shows I have the correct channel map. Did you use a dsmx protocol from another build? Thanks in advance!
DEVO F12E | Devo F7
02 Sep 2017 04:13 #64113 by firefoxf18
Replied by firefoxf18 on topic How to load an F12E with Deviation(Possibly F7)
Would somebody kind enough to post a youtube clips for this topic to enlighten moron like me please!!!!!
02 Sep 2017 04:29 #64114 by RubenRC
Firefox you'll be lucky to get a response let alone a vid. But I'll do my best to help what's up?
DEVO F12E | Devo F7
02 Sep 2017 04:57 - 02 Sep 2017 05:05 #64116 by firefoxf18
So nice to hear from you!!! Many thanks in advance!!! I still couldn't get my DEVO F12E upgraded with the nighty build firmwares. Even when it appeared upgraded, I cannot get it binded with any Walkera Quads [F320 and scout X4], not to mention any DSM2 receiver.!!!!
Last edit: 02 Sep 2017 05:05 by firefoxf18.
02 Sep 2017 05:02 #64118 by RubenRC
Okay 1st what loader are you using to load Deviation? Then did you install drivers to connect your controller? If so did the loader identify the controller once connected? I think that's a good start to figure out your issue.
DEVO F12E | Devo F7
02 Sep 2017 05:08 #64119 by firefoxf18
I use the 'DevoDfuSe', I don't think I have installed any driver, but the loader identify the controller in order.
02 Sep 2017 05:11 #64120 by RubenRC
Okay. So what does your transmitter do when you power it on?
DEVO F12E | Devo F7
02 Sep 2017 05:59 #64121 by firefoxf18
The menu appears normal, but when I tried to bind my walkera f320 or scountX4, it just couldn't bind at all!!!! When I restore the original devo firmware, it all goes fine!!!! Really dont know what is the problem.!!!
03 Sep 2017 18:49 #64150 by Cyberkul11
Replied by Cyberkul11 on topic How to load an F12E with Deviation(Possibly F7)
Same Problem with 9c46f3b Build - No DSM2 and DEVO Bind`s.
DSMX Works.
05 Sep 2017 17:50 #64206 by RubenRC
you guys will need to pull those protocols from the build zip and then add it to the devo.fs file using the build.exe command. attached is a screenshot of the protocols you need to extract then now to the folder you use to create the devo.fs file you will need to copy to the F7 when you have it in usb mode.
DEVO F12E | Devo F7
02 Jun 2021 19:24 #77413 by oskarra
Ruben RC has conseguido que funcione todo en una DEVO F7?
Time to create page: 0.219 seconds
