Need help to setup switch on devo 7e
28 Oct 2016 21:08 - 28 Oct 2016 21:08 #55492 by zorkx
Can you guys please help me to configure both switches on my modded devo 7e ?
Wan't to use one for arming and the other for angle / horizon mode in betaflight, bought a eachine qx90 but the quad won't arm the motors because the switches won't change rate.
I don't know how to configure it in the devo 7e mixer menu, i guess it's channel 5 and 6 ?
Last edit: 28 Oct 2016 21:08 by zorkx.
30 Oct 2016 00:29 - 30 Oct 2016 00:30 #55510 by HappyHarry
Replied by HappyHarry on topic Need help to setup switch on devo 7e
I'm not sure which channels are set as stock on the qx90 but I'm sure you can change them in the flight controller software you have used on the fcb. as for the switches on the 7e they can be assigned to any channel and whatever you need them to do by using the mixer menu on the tx
Last edit: 30 Oct 2016 00:30 by HappyHarry.
30 Oct 2016 06:37 - 30 Oct 2016 06:39 #55512 by Alexandro
Replied by Alexandro on topic Need help to setup switch on devo 7e
It is Cannel 5 and 6.
At Cleanflight Aux 1 and Aux 2
Mix:
Cannel 5 , use a 2 Pos Switch
Source is the Switch and thats for 2 Pos
Cannel 6 , use a 3 Pos Switch. Mix is Complex. 3 Pages. Always replace
1st Mixer ,Source is Switch pos 0 and Switch is the same pos 0. Way is here 100
2nd Mix , Source is Switch pos 1 and Switch is the same pos 1. Here set the Way to 0
3rd Mix , Source is Switch pos 2 and Switch is the same pos 2 . Set the way to -100
At Cleanflight go to the Flight Modes and check the Aux 1 and Aux 2
Pull the green Band to the right Switch Pos.
Flight Mode is the 3 Pos. Switch, here use Angle , Horizon, and the 3rd is nothing.
Then you have 1 Stabilized 2 only Horizon 3 full 3d Mode
I hope it helps to understand the 3 Pos Switch Mix. Btw. Allways press ok to save the Mix Page, do not use Exit
My 2ct. Alex
Last edit: 30 Oct 2016 06:39 by Alexandro.
30 Oct 2016 09:34 - 30 Oct 2016 09:36 #55514 by zorkx
Replied by zorkx on topic Need help to setup switch on devo 7e
For channel 5 i changed in the mixer menu
simple
5 src ch5
curve zero/max
scale 100
offset 0
saved configuration
But when i test it in channel monitor it won't change rate after switching, channel 5 always stay on 100
Tried same procedure for channel 6 because i thought maybe the switch is broken but same result --> value 100
Last edit: 30 Oct 2016 09:36 by zorkx.
30 Oct 2016 10:04 - 30 Oct 2016 10:10 #55516 by Alexandro
Channel Monitor on Devo or Cleanflight ?
File Attachment:
File Name: model20.ini
File Size:4 KB
Last edit: 30 Oct 2016 10:10 by Alexandro.
30 Oct 2016 10:21 #55517 by zorkx
Channel monitor on the Devo.
Is this the proper config file ?
30 Oct 2016 10:32 #55518 by Alexandro
This is my QX95 Model File ,Yes there is 2 Pos for Arm and 3 Pos for Flight Mode.
It is from my Devo6s and it works.
I set a Mix for Yaw to Elevator for better slow Turing on yaw.
Check the Ail and Rud Cannel, i use Mode 3
Check the Aux1 and Aux 2 on Cleanflight.
greetings Alex
Time to create page: 0.700 seconds
