4 in 1 Installation
- Flatshad
30 Dec 2016 15:22 - 30 Dec 2016 15:26 #57362
by Flatshad
4 in 1 Installation was created by Flatshad
First post here I hope I'm in the right place for this. I've had my 4 in 1 module for about a month now waiting on my DEVO 10 to arrive. It finally got here yesterday so I updated to the nightly build of Deviation first no problem at all. Then I opened the case and installed the module, went in and edited the hardware file and fired up the DEVO. This is when things didn't go so good. I got the missing module warning. I've went back and triple checked everything I can think of and reinstalled Deviation a couple of times and I'm still getting the warning. If anyone can point me in a direction to cure this it would be appreciated. I've read on this board till my eyes are crossed and tried all that I can find. HELP please!! Should I try to roll back to an earlier build?
Last edit: 30 Dec 2016 15:26 by Flatshad.
30 Dec 2016 15:30 #57363
Replied by vlad_vy on topic 4 in 1 Installation
Try to use 2016-12-18 nightly build or v5.0.0 release. There are many code changes after 2016-12-18 build.
- dado099
30 Dec 2016 17:13 - 30 Dec 2016 17:16 #57365
by dado099
Replied by dado099 on topic 4 in 1 Installation
A detailed picture of module installation with wiring could help....
Also hardware.ini
Also hardware.ini
Last edit: 30 Dec 2016 17:16 by dado099.
- FlipRide1
30 Dec 2016 20:12 #57370
by FlipRide1
Replied by FlipRide1 on topic 4 in 1 Installation
Tried reformatting your devo?
- Flatshad
30 Dec 2016 20:17 #57371
by Flatshad
Replied by Flatshad on topic 4 in 1 Installation
Here's the hardware.ini & pic of the installation. Hope this helps. This is the original hardware file before being edited. The one on the devo has the semi colons removed. What I'm not sure about is the connection point numbers. (not sure what they're called)
- Flatshad
30 Dec 2016 20:40 #57372
by Flatshad
Yes I've reformatted it several times.
- dado099
30 Dec 2016 21:24 #57375
by dado099
You have two modules both on a14, I think nrf module should be B7 on devo 10
Anyway please post the current hardware.ini to fully check (without semicolons).
- justyn07
30 Dec 2016 21:43 #57376
by justyn07
Replied by justyn07 on topic 4 in 1 Installation
try this ; there is no need to enable the cyrf6936 module unless
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
; enable-multimod = A13
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- Flatshad
30 Dec 2016 23:50 #57380
by Flatshad
I tried these settings and don't get the warning but the modules aren't loaded with the ; enable-multimod = A13. If I remove the semi colon the warning comes back.
- HappyHarry
31 Dec 2016 06:34 #57393
by HappyHarry
there is an issue with the latest nightlies, do as vlad_vy suggests in the post I've quoted
Replied by HappyHarry on topic 4 in 1 Installation
vlad_vy wrote: Try to use 2016-12-18 nightly build or v5.0.0 release. There are many code changes after 2016-12-18 build.
- dado099
31 Dec 2016 08:04 #57394
by dado099
you must not uncomment enable-multimod, simply because you don't have it.Flatshad wrote: I tried these settings and don't get the warning but the modules aren't loaded with the ; enable-multimod = A13. If I remove the semi colon the warning comes back.
- Flatshad
03 Jan 2017 02:55 #57495
by Flatshad
Sorry I'm just getting back to answer everyone's helpful posts. It looks like everything is up and running as it's suppose to now. Thx for all the help.
- sufu
04 Jan 2017 04:25 #57520
by sufu
Replied by sufu on topic 4 in 1 Installation
Too late info sorry, attached picture are my case.
Tested CYRF6936 and CC2500, but not tested A7105 and NRF24I01.
- kaligola
07 Jan 2017 14:57 #57631
by kaligola
Replied by kaligola on topic 4 in 1 Installation
i just got my devo 10 , is this module same range of origina?
im planning to buy one. in 7e i have 3 but 10 has more future upgrades
thanks
thanks
- Air.7386
- Air.7386
26 Jun 2020 14:00 #76530
by Air.7386
Replied by Air.7386 on topic 4 in 1 Installation
Help....i have short in this place....
Time to create page: 0.298 seconds
