elevator stick as a flip flop switch for DLG
- dragonf3b
11 Mar 2017 08:36 #60116
by dragonf3b
elevator stick as a flip flop switch for DLG was created by dragonf3b
I like to switch the flight mode during DLG start by moving the elevator stick over a defined position. At the highest point I want to switch from START to NORMAL without touching an extra knob.
I found a way to do this, the switch acts like a flip; reset (flop) is done by the unused trim-knob.
How it works:
on the mixer:
select an unused virtual channel, rename it for better understanding (e.g.: TRM-SW)
set the type to 'complex'
set the source to 'TRM-SW'
set the Curve to '1to1'
set the scale to '0'
set the trim button to 'Trim'
SAVE
Next:
on the trim page:
select the unused TRIM (THR)
set the INPUT to an unused virtual channel (TRM-SW)
set the step to 'Momentary'
set the Trim+ to the trim in question
set the Trim- to None
SAVE
Now the Flip-switch:
on the mixer:
select an unused virtual channel, rename it for better understanding (e.g.: FH1, flip helper 1)
set the Source to 'elevator'
set the Curve to 'MIN/MAX'
Enter 'MIN/MAX'
set the switch value to desired (e.g. '50'), SAVE ; here you define the switch point
set the scale to '100'
set the trim button to 'NO Trim'
SAVE
now do the same same with a second virtual channel:
select an unused virtual channel, rename it for better understanding (e.g.: FH2, flip helper 2)
Enter 'MIN/MAX'
SAVE
now the FLIP:
select an unused virtual channel, rename it for better understanding (e.g.: FLIP)
set Mixers to '2'
goto page 1
set the Switch 'FH1'
set MUX to 'replace'
set the Source to 'FH2'
SAVE
goto page 2
set the Switch 'TRM-SW'
set the Source to 'FH1'
SAVE
That's it. Now you can use the FLIP channel as a switch for whatever, reset by unused trim knob.
greetings
Achim
How it works:
on the mixer:
SAVE
Next:
on the trim page:
SAVE
on the mixer:
Enter 'MIN/MAX'
SAVE
Enter 'MIN/MAX'
SAVE
now the FLIP:
set Mixers to '2'
goto page 1
SAVE
goto page 2
SAVE
greetings
Achim
Time to create page: 0.248 seconds
