Elevon D/R Mixing ...
02 Sep 2018 04:22 - 02 Sep 2018 04:24 #70612 by old4570
Elevon D/R Mixing ... was created by old4570
Elevon with D/R
SW D1 ( Position ) Set your scale ( RATE )
SW D2 ( Position ) Set your scale ( RATE )
Aileron - Complex - 4 mixes
Page 1 - Switch = SW D1 - Mux = Replace Source = Ele - Curve = 1 to 1 - Scale ?
Page 2 - Switch = SW D1 - Mux = Add Source = !Ail - Curve = 1 to 1 - Scale ?
Page 3 - Switch = SW D2 - Mux = Replace Source = Ele - Curve = 1 to 1 - Scale ?
Page 4 - Switch = SW D2 - Mux = Add Source = !Ail - Curve = 1 to 1 - Scale ?
Elevator - Complex - 4 mixes
Page 1 - Switch = SW D1 - Mux = Replace Source = Ail - Curve = 1 to 1 - Scale ?
Page 2 - Switch = SW D1 - Mux = Add Source = Ele - Curve = 1 to 1 - Scale ?
Page 3 - Switch = SW D2 - Mux = Replace Source = Ail - Curve = 1 to 1 - Scale ?
Page 4 - Switch = SW D2 - Mux = Add Source = Ele - Curve = 1 to 1 - Scale ?
So you go to mixing ...
Ail ..
Chose Complex for your mix
Then you will be setting up either 4 mixes or 6 mixes depending on the switch you want to use ( 2 position / 3 position )
Then just follow the example I have given you ...
My transmitter is the Jumper T8SG Lite , and my first switch position ( 3 position switch ) is my safety ( Throttle cut )
And as I bring the switch to the middle position ( SW D1 ) I have 50% rates ...
In the SW D2 ( lowest ) position I have 100% rates ..
Hope this helps ...
Last edit: 02 Sep 2018 04:24 by old4570.
13 Jan 2019 18:45 #72309 by thyng@att,net
Replied by thyng@att,net on topic Elevon D/R Mixing ...
How do I set up elevons for a delta wing airplane? I wouldn't think there would be any switches involved as the set-up would always be active.
14 Jan 2019 01:44 #72314 by Gerry
Replied by Gerry on topic Elevon D/R Mixing ...
See this topic. www.deviationtx.com/forum/model-template...ith-dual-rate-please
examples and a walkthrough are there.
FFS (Forever Fixing Stuff)
Time to create page: 0.023 seconds
