Carn't upgrade my Devo12s
01 Jan 2020 12:36 #75641 by Berryman
Carn't upgrade my Devo12s was created by Berryman
I have come back to my heli's and my devo 12s after pursuing other interists and I thought I would upgrade my Devo12s because I was thinking of getting another model and I didn't want to buy another receiver to bind with the next model so all I am left with is the usb symbol it want upload the files.
WHO CAN HELP?
01 Jan 2020 15:37 #75642 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Carn't upgrade my Devo12s
I'm not sure if i understand what you're asking.
1. do you want to install your Devo 12s with a new firmware or
2. do you want to save an ini file in the Devo for a new model?
02 Jan 2020 01:55 #75643 by Berryman
Replied by Berryman on topic Carn't upgrade my Devo12s
I have downloaded deviation newest version to my controller and now all I get when I turn the controller on is the USB symbol on the LCD screen.
02 Jan 2020 06:13 #75644 by -=Hubi-Dirk=-
Which you should start with:
Use the latest version of the DfuSe tool.
walkera-fans.de/download/tools/dfuse/Dfu...rade-Tools-3.0.5.zip
Read and follow the instructions for installing Deviation on the 12s. Please note the special installation of the library file.
deviationtx.com/user-manual/user-manual-6-8-12
02 Jan 2020 06:46 - 02 Jan 2020 06:49 #75645 by vlad_vy
Replied by vlad_vy on topic Carn't upgrade my Devo12s
Do not use DfuSe 3.0.5, it's DfuSe Demo. You can destroy bootloader with it.
Use Dfuse USB Upgrade Tools v2.31
walkera-fans.de/download/tools/dfuse/Dfu...e%20Tools%202.31.zip
If you have USB logo on screen, you need format the transmitter USB drive and copy the filesystem from firmware archive.
Last edit: 02 Jan 2020 06:49 by vlad_vy.
02 Jan 2020 09:43 #75647 by Berryman
I've try everything four or five times file look like they have loaded but it want turn on just get the USB symbol and now it it want even connect to the Dfuse USB upgrader I think it might be wiped.
02 Jan 2020 11:10 - 02 Jan 2020 11:10 #75648 by -=Hubi-Dirk=-
vlad_vy wrote: Do not use DfuSe 3.0.5, it's DfuSe Demo. You can destroy bootloader with it.
Thanks for the information, Vlad!!!
Last edit: 02 Jan 2020 11:10 by -=Hubi-Dirk=-.
02 Jan 2020 11:33 #75649 by Berryman
It will not do anything will not show up on the defuse updater but will format but I think it might be wiped by deviation I think I'm going to have to get a new transmitter.:( :(
02 Jan 2020 12:23 #75650 by Mack775
Replied by Mack775 on topic Carn't upgrade my Devo12s
You can install devention firmware and start over if need be. I have fashed 3 12s and love the touch screen. Just be sure to use 2.31.
03 Jan 2020 03:04 #75652 by Berryman
Thanks everyone I have tried all of the suggestions but all I am getting is still the USB symbol on the screen when I turn the transmitter back on.
It's stuffed !
Any other suggestions.
03 Jan 2020 04:59 #75653 by -=Hubi-Dirk=-
Could you reformat the memory in the Devo 12s using a file manager (Windows Explorer for example) with the FAT file system?
You can NOT use DfuSe for this action.
04 Jan 2020 14:42 #75658 by Mack775
You have to get the file system on the 12s before it will work. The 8s and 12s have to be flashed with media.dfu under the media tab. Go back and read the forum about all flashing. I got and f7 stuck in usb sometime back and got it to work. Don't give up when you get it right it will work. Study the forum.
04 Jan 2020 18:41 #75659 by aMax
Replied by aMax on topic Carn't upgrade my Devo12s
This happened to my 7e two years ago. The file system could not be recovered by flashing a Deviation release and windows was not able to format the flash. After several tries I finally flashed the original firmware
for this transmitter and tested a model upload. All this worked with the Walkera Firmware.
Then I started new with Deviation and how should I say, it worked this time. Fortunately I had a current backup of the models.
04 Jan 2020 22:11 #75660 by Mack775
lib.dfu with library tab sorry.
05 Jan 2020 06:17 - 05 Jan 2020 06:17 #75664 by -=Hubi-Dirk=-
Mack775 wrote: You have to get the file system on the 12s before it will work. The 8s and 12s have to be flashed with media.dfu under the media tab. Go back and read the forum about all flashing. I got and f7 stuck in usb sometime back and got it to work. Don't give up when you get it right it will work. Study the forum.
This is only right for the Devo 12s, not for the Devo 8s.
Last edit: 05 Jan 2020 06:17 by -=Hubi-Dirk=-.
Time to create page: 0.118 seconds
