Blade 300x with AR7200BX BeastX
- Spyro37
09 Jan 2014 15:51 #18284
by Spyro37
Replied by Spyro37 on topic Blade 300x with AR7200BX BeastX
Alright, yes, it's gotta be the gyro settings on the Tx, which I did not check and even think of.
I will be gone for a day or two, and will work on it again as soon I get home.
Thanks much for all the help.
- djsmeegy
06 Oct 2014 09:57 #25966
by djsmeegy
Replied by djsmeegy on topic Blade 300x with AR7200BX BeastX
Hello guys,
I have DEVO 10 w/ deviation v3.0.0 and I have 450L with AR7200BX.
I need your help.
When I've been making setup of AR7200BX, I tried to have there pitch curves: FMODE0 -5 to +11.5, FMODE1 -5 to +11.5 and FMODE2 -11.5 to +11.5. For FMODE1 and 2 I've been suscced.
But for FMODE0 Im able to set only 0 to 11.5.
Also, once Im making setup of AR7200BX, Im using same setup in tx (dont remove the curves)..
Can you please help me?
What am I doing bad?
Is it the problem, that in menu G (during setup AR7200BX) I set exact zero pitch of blades and in my tx it's -5?
Is is OK to make setup of AR7200BX, when I'm using same setup in tx (don't remove the curves)?
Here is my ini file. Inthere is model called DFC, but Im using same template for another bird, just renamed it in tx and have not put copy to PC yet.
I need your help.
- kiwi-craig
05 Nov 2016 18:51 - 05 Nov 2016 18:52 #55726
by kiwi-craig
Replied by kiwi-craig on topic Blade 300x with AR7200BX BeastX
Guys, loaded the ini file into my devo 10, bound to my 300CFX, had to used dsm2.
Everything works BUT the curve functions for ail / ele / rudder second tab settings do not work at all ?
only way I can scale the servo movements is in the front section of the ail / ele / rudder tabs with the scale function there and the numbers have to be really small to have an effect like 25 - 30 once over 40 you have full travel range onto servos. all my other devo ini files / models I can scale and alter the curves in the second tab, have dual rates switching with the complex settings options etc.
how do you set dual rates and expo into this file / AR7200BX ?
I really need to tame this thing down so I don't junk it first fly !
what am i missing - not understanding here ?
thanks
thanks
Last edit: 05 Nov 2016 18:52 by kiwi-craig.
- djsmeegy
05 Nov 2016 19:05 #55727
by djsmeegy
Hello, I have devo10 and t-rex 450L w/ AR7200BX and I have set the dual rates.
Dual rates mean the full rate of servo-ie scale 100 and the normal rates mean the scale is 50.
So actually you decrease the servo travel to the half.
When you're doing the setup on beastx, you have to have the d/r on- so the servo travel is 100%.
I can post you my ini file later on.
- kiwi-craig
05 Nov 2016 19:06 #55728
by kiwi-craig
i spotted this:
One thing you should check is Parameter Menu item "B" in your BX.
The default setting for this item is (SPORT). It's a preprogrammed control behavior. If you have this setting you can't have D/R or Expo in your TX. It conflicts with the control program.
If you want to use D/R, and Expo then select (Transmitter - Blue Solid) in the same menu item.
so I need to alter the beast X setting allow D/r and expo ?
thanks
thanks
- kiwi-craig
06 Nov 2016 01:04 #55731
by kiwi-craig
went through the parameters menu, B was set on solid blue = transmitter, went accept curve scaling etc.
tried the user defined setting, still no good........
- djsmeegy
06 Nov 2016 11:05 - 06 Nov 2016 11:52 #55736
by djsmeegy
I have been using the sport setup and now I have set tx in parametr B of beastx, but in both settings, my D/R was working.
Try to compare your ini with my one.
Last edit: 06 Nov 2016 11:52 by djsmeegy.
- kiwi-craig
06 Nov 2016 19:13 #55748
by kiwi-craig
I've transferred in the dual rates coding to no effect and tried different menu B settings (user define, normal, TX defined modes) with no change.
I see your using DSMX, original file in this thread, which is what i'm using is DSM2 ? I'll try rebinding in DSMX mode ?
might update to the new 5.0.0 software whilst I'm at it.
- kiwi-craig
07 Nov 2016 06:06 #55767
by kiwi-craig
rebound in DSMX, no change ? beats the heck out of me........
- djsmeegy
07 Nov 2016 06:17 #55768
by djsmeegy
Try to make new beastx setup with the D/R entabled, ie 100% travel, and with no curves in tx. After that you should be able to use the normal (50%) and D/R (100% servo travel).
- trhodes
10 May 2017 23:52 #62224
by trhodes
Replied by trhodes on topic Blade 300x with AR7200BX BeastX
Can someone tell me what to reverse in the transmitter. My collective moves in the right direction when the stick moves up and down but when I move the right stick the movements are opposite what they should be.
- kiwi-craig
15 May 2017 06:21 #62312
by kiwi-craig
gave up on the devo and bought a DX8, all works perfectly now........ clearly there is a subtle digital handshake going on,spectrum radio to the AR7200 unit..........
Time to create page: 0.604 seconds
Model Configs
- Blade 300x with AR7200BX BeastX
