Need Solo Pro 328a
12 Dec 2012 00:06 - 12 Dec 2012 00:08 #3897 by gwrivest
Need Solo Pro 328a was created by gwrivest
Hi guys, I just installed Deviation on my Devo 10 and I managed to bind my Solo Pro 328a to it but I'm having a hard time figuring out how to configure it. It seems to have the Ele. and Ail. reversed (left is right, right is left, and same for forward and backward). I tried reversing the channels but that had no effect. Does someone have a working SP 328a set-up? Could you share the file? Thanks in advance.
Gerard.
Last edit: 12 Dec 2012 00:08 by gwrivest.
23 Dec 2012 17:13 #4221 by quique65
Replied by quique65 on topic Need Solo Pro 328a
I've just configured a Solo Pro 180 with J6Pro protocol. If the 328a RX it's similar you need to change the channels for AIL ,ELE and Gyro.
ELE (1 in WK) - 2 in J6
AIL (2 in WK) - 1 in J6 (reversed in Solo Pro 180)
GYRO (7 in WK) - 5 in J6
Regards,
Enrique.
23 Dec 2012 21:35 #4239 by gwrivest
Replied by gwrivest on topic Need Solo Pro 328a
Thank you but I finally have it working properly now. Very basic set-up without dual rates and expo set up yet. I may try to share my model config file later on.
Gerard.
Time to create page: 0.197 seconds
