Need Config for 4G6S (CP-Heli) (RX2609)
17 Dec 2012 18:47 #4066 by Fernbediener71
Need Config for 4G6S (CP-Heli) (RX2609) was created by Fernbediener71
Hi!
Has someone the Settings for a 4G6s CP-Heli?
The template for 6CH does not match with the Servos/Swashplate...
03 Jan 2013 15:29 #4616 by Fernbediener71
Replied by Fernbediener71 on topic Need Config for 4G6S (CP-Heli) (RX2609)
Here ist a basic setting for the 4G6. Evereyone should modyfy expo etc for his own use.
10 Jan 2013 20:14 #4907 by oldhui
Replied by oldhui on topic Need Config for 4G6S (CP-Heli) (RX2609)
I have a 4G6S with RX2610S and the config does not seems to work.
Seems that I have to set the swash to 120 as CCPM is needed. The RX2610S only binds with the WK2601 protocol, not the WK2801. And the problem is not getting the PIT servo to work properly.
According to the Deviation manual, under the WK2601 protocol, setting "Chan" to "5+1" will leave channel 6 disabled. Thus the PIT servo is not getting anything.
Setting Chan to "Heli" links the COL channel with the THR. This surely will not work.
Setting Chan to "6+1" gives some weird movement of the 3 servos.
In the channel monitor, the 3 cyclic channel output look ok. It is just when it is on the RX2610S then the swash gets messed up.
Anyone has a solution?
10 Jan 2013 20:21 #4908 by Joshua
Replied by Joshua on topic Need Config for 4G6S (CP-Heli) (RX2609)
I have the same problem with my 4G3 with RX2605 receiver.
No solution until now. :(
13 Jan 2013 02:38 - 13 Jan 2013 02:39 #4952 by SamtheMan
Replied by SamtheMan on topic Need Config for 4G6S (CP-Heli) (RX2609)
I have the CB100 with the 2605A, I bought it last week, have yet to fly it one time. I did not buy a WK radio, and this firmware doesn't seem to be working right for it either. Its supposed to take 2801 or 2601, but only 2601 protocol binds with it, and I am too new to know whats "wrong" ... I know it was flight tested before I bought it, but honestly too noob to know if its the bird or the firmware, but it does NOT do what its commanded to do. I spent $300 on this, and man do I want to fly it. I hope I dont have to buy a 2801, its $100 when buying the copter, but alot more stand alone.
Last edit: 13 Jan 2013 02:39 by SamtheMan.
  • rbe2012
  • rbe2012's Avatar
13 Jan 2013 10:21 #4962 by rbe2012
Replied by rbe2012 on topic Need Config for 4G6S (CP-Heli) (RX2609)
Seems to be a bug in the 2601 protocol (see at PBs posting ). Stay tuned, perhaps there is a connection.
13 Jan 2013 12:13 #4966 by SamtheMan
I got my cb100 working will post a model config. It is 2605a but its only 4 channel.
26 Aug 2013 00:11 #13285 by dwhacks
Replied by dwhacks on topic Need Config for 4G6S (CP-Heli) (RX2609)
Any news? I would really like to fly my 4g6s with this radio!
Time to create page: 0.172 seconds
