Hubsan X4 config
- proteus
31 Dec 2012 12:54 #4417
by proteus
Hubsan X4 config was created by proteus
Hello
my X4 config :
2 mode
- 70% dualrate (rudder 60%), 25% expo --> green icon
- 100% dual rate, 0% expo (3D) --< yellow icon
throllte cut : RUD DR --> red icon
2 chrono throttle command
for model icon :
www.deviationtx.com/forum/model-icons/1081-hubsan-x4
my X4 config :
2 mode
for model icon :
- Rain4LA
07 Feb 2013 16:45 #6126
by Rain4LA
Replied by Rain4LA on topic Hubsan X4 config
Hey, thanks for doing the work and posting this. It works great for me.
- SamtheMan
12 Feb 2013 21:05 #6332
by SamtheMan
Replied by SamtheMan on topic Hubsan X4 config
So both you guys modded your radios with that module?
- proteus
13 Feb 2013 16:55 - 13 Feb 2013 16:56 #6363
by proteus
Replied by proteus on topic Hubsan X4 config
Last edit: 13 Feb 2013 16:56 by proteus.
- Joshua
13 Feb 2013 17:16 #6366
by Joshua
I use same modul with my Revell QG 550 and it works fine.
www.deviationtx.com/forum/3-feedback-que...upport?start=20#6027
Replied by Joshua on topic Hubsan X4 config
proteus wrote: with A7105-500m module for me
www.deviationtx.com/forum/how-to/1228-fl...le-with-pics-devo-8s
- proteus
06 Apr 2013 09:58 #8619
by proteus
Replied by proteus on topic Hubsan X4 config : new for 3.0.0
for toggle.bmp : www.deviationtx.com/forum/custom-skins/1...tion-icon-toggle-bmp
- HeliBen
06 Jul 2013 06:04 #12004
by HeliBen
Replied by HeliBen on topic Hubsan X4 config
Anyone have the v2 hubsan x4? just wondering its possible to turn the lights on or off with a switch.
- jason4207
10 Jul 2013 03:46 #12158
by jason4207
Just got mine today. I'm also curious on how to get this working.
Replied by jason4207 on topic Hubsan X4 config
HeliBen wrote: Anyone have the v2 hubsan x4? just wondering its possible to turn the lights on or off with a switch.
- goebish
- NRF Weirdo
26 Jul 2013 15:49 - 26 Jul 2013 15:56 #12530
by goebish
Replied by goebish on topic Hubsan X4 config
+1
Would be cool to be able to turn off LEDs and most importantly disable auto flip feature while keeping full throws.
I would be glad to help, I've got a hubsan x4 v2 transmitter and a 24MHz logic analyzer but I've no idea of how the A7105 works
(looks like it's not SPI).
Maybe someone can give me some clues so I can tell the devs what are the frames to send ?
Just a guess: has someone tried to enable Ch5 or Ch6 and send different values at them ?
I've not tried by myself because that's my first day on devo10 / deviation (first thing I did was flashing deviation and installing a A7105 module
) after 4 years with a DX6i, programming deviation is a BIT more difficult, I still have a lot of things to figure out !
Thanks.
Thanks.
Last edit: 26 Jul 2013 15:56 by goebish.
- sbstnp
26 Jul 2013 16:53 - 26 Jul 2013 16:54 #12533
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Hubsan X4 config
There are no ch5 and ch6 for the Hubsan as of yet, you cannot go above channel 4.
Devo 10 + 4in1
Last edit: 26 Jul 2013 16:54 by sbstnp.
- goebish
- NRF Weirdo
27 Jul 2013 00:44 #12541
by goebish
Ok thanks.
I took the plunge and I'm trying to figure out how it works.
Help is welcome
www.deviationtx.com/forum/protocol-devel...d-version-on-the-way
Help is welcome
- goebish
- NRF Weirdo
- sbstnp
27 Jul 2013 18:36 #12555
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
I should have worder things differently: "there is no user accessible channel over 4 in the current implementation"
goebish wrote: Looks like I found the 5th channel
www.deviationtx.com/forum/protocol-devel...ion-on-the-way#12552
Devo 10 + 4in1
- goebish
- NRF Weirdo
29 Jul 2013 12:23 - 22 Aug 2013 02:22 #12590
by goebish
Attached is a profile for the Hubsan X4 v2 (H107-L):
it requires my patch in deviation for the leds and disable flips functions to work:
bitbucket.org/PhracturedBlue/deviation/p...l-for-hubsan-x4/diff
If you can't build it by yourself and can't wait it is included in the nightly build you might send me a PM and I'll send you the firmware for your TX.
Patch is now included in nightly build.
edit 2013-08-22: proper throttle curve and ail/ele/rud expos.
GEAR 0 -> lights on
GEAR 1 -> lights off
FMODE 0: 75% throws / 60% RUD, -10% expo AIL/ELE, +30% expo RUD
FMODE 1: 90% throws / 70% RUD, -10% expo AIL/ELE, +30% expo RUD flips disabled
FMODE 2: 90% throws / 70% RUD, -10% expo AIL/ELE, +30% expo RUD flips enabled
RUDD D/R 1 -> throttle cut
GEAR 0 -> lights on
Last edit: 22 Aug 2013 02:22 by goebish.
- thibaut47
31 Jul 2013 21:00 - 31 Jul 2013 22:18 #12670
by thibaut47
hello, i have a DEVO8S + deviationTX naughty build 3.0.0. I had download the model *ini below for my x4 v2 but it doesnt bind. blue light keep flashing and not go to a solid blue. Any idea ? ( i fly without any problem my nano QX + hoten X with deviation 3.0.0 naughty build and my devo8) . Thx for help
Replied by thibaut47 on topic Hubsan X4 config
Last edit: 31 Jul 2013 22:18 by thibaut47.
- goebish
- NRF Weirdo
31 Jul 2013 22:33 - 31 Jul 2013 22:47 #12671
by goebish
Last edit: 31 Jul 2013 22:47 by goebish.
- thibaut47
31 Jul 2013 22:51 #12672
by thibaut47
i have not.
thx you for the answer !
- goebish
- NRF Weirdo
31 Jul 2013 22:54 #12673
by goebish
If you know how to handle a soldering iron this is not difficult to do at all.
Details here:
www.deviationtx.com/repository/Documenta...uleInstallation.pdf/
You can get the module for $10-$15 (ebay A7105 500m).
Details here:
- thibaut47
31 Jul 2013 23:11 #12674
by thibaut47
ok ! i will take a look. thx again
- sbstnp
01 Aug 2013 02:33 #12675
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Naughty build LOL
Devo 10 + 4in1
Time to create page: 0.129 seconds
Model Configs
- Hubsan X4 config
