Reversing Pitch in the Model File
20 Jan 2013 12:39 #5241 by lasakro
Reversing Pitch in the Model File was created by lasakro
I using a Devo 10 with the current FW, RX802 and a BeastX. The Aile and Pit servos are operating in the opposite directions between cyclic and pitch control. In the BeastX I can swap the direction so that they are correct for cyclic or pitch but can't get them to operate in the correct direction for both. I'm still struggling a little with the mixing sources in the model file. Hexperience's "How to set up FBL helis on Custom Firmware" write up is fantastic but I'm still having a problem linking some of the theory to the file itself. Is there something out there that may help me better understand this in the future? All valid file entries for example? For now I've attached what I'm working with. Signed, Stuck.
21 Jan 2013 00:21 #5289 by flint723
Replied by flint723 on topic Reversing Pitch in the Model File
Here is a model with some reversed channels. Hope that will help.
File Attachment:
File Name: model5.ini
File Size:4 KB
21 Jan 2013 02:42 #5292 by lasakro
Replied by lasakro on topic Reversing Pitch in the Model File
Got it. There where two scale-=0 lines in there. Must be similar to reverse=1. Once removed the model works correctly for the 480. Thanks.
Time to create page: 1.112 seconds
