blade mcpx bl please help !
17 Feb 2013 15:58 #6481 by Boni7league
blade mcpx bl please help ! was created by Boni7league
Hello, I have a probleme with my mcpx bl, I bought him(it) ya 4 days and dashed the defis to couple him(it) with my devo8 deviation knowing that apparently nobody on this forum has him(it), I have bind with my transmitter and the cyclic works correctly except the rudder!!! That I act on the command(order) rudder towards the meme left little the engine stop, I have to put the stick rudder has bottom has right so that the engine rudder flares up again, I tried differents possibilities whose inversion sees rudder and resultat the engine cuts has right and relights has left ca does not come from the helicoptere but has a reglage of the radio but which??? Please help me, thanks. :blush: :(
17 Feb 2013 18:32 #6483 by gapi
Replied by gapi on topic blade mcpx bl please help !
Gosh, I cannot make anything out of your language translation to English.
17 Feb 2013 20:31 #6487 by stevecox
Replied by stevecox on topic blade mcpx bl please help !
Sounds like the tail rotor only swings one way or perhaps full on an input. More than likely need to set the gyro sensibility channel, I got the same effect until I set the gyro sensibility when trying to setup a FBL100 from nothing just trial and error.
Adelaide
Time to create page: 0.027 seconds
