Anyone Have a Brushless Master CP Model To Share?
06 Mar 2013 00:04 #7399 by gapi
I just went Brushless on the Master CP's main motor and would love to see other folks models if anyone is doing the same.
Its definitely a different animal with the Brushless main motor. A much stronger feel and it ramps up faster.
06 Mar 2013 07:37 #7418 by domcars0
There is no important differences in the TX configuration between a model with a brushed motor and the same (RX, module FBL, servos, geometry ....) with a brushless motor. I think you can take the model.ini of the stock Master CP and just lower the throttle curve (70% is probably enough).
06 Mar 2013 10:14 #7422 by gapi
Would you do that in the Scale Setting going down from 100 to 70, or in the 7 - Point?
thanks
06 Mar 2013 15:56 #7430 by domcars0
gapi wrote: Would you do that in the Scale Setting going down from 100 to 70, or in the 7 - Point?
thanks
I would probably do that in the 7 pts curve.. but in Scale setting it will be ok also...
