Solo Pro 125 finetuning
21 Mar 2013 20:39 #7973 by Lars
Solo Pro 125 finetuning was created by Lars
Hello, i am using deviation 2.1.1 on my Devo 8, and got my new SP 125 configured pretty good. However, i dont get the tail properly locked it dirfts left or right and i dont get it fixed. Any ideas on a fix i greatly appreciate. Also a question: is there a way to setup gyro percentage ? Anyone knows what channel that is on on the SP 125 reciever ?
22 Mar 2013 00:57 - 22 Mar 2013 01:01 #7982 by rototophe
Replied by rototophe on topic Solo Pro 125 finetuning
Gyro setting is on channel 5 on SP125. I personally use the GEAR switch on that channel with a complex mixer. I did set one position of the switch with a flat curve set at 50 and the second position of the switch with a flat curve set a -30. These settings should be equivalent to the recommended gyro settings when using the J6Pro Tx.
I use these settings successfully with my SP125. You might want to fine tune to your needs. In any case this should give you a good place to start.
Cheers! :)
Last edit: 22 Mar 2013 01:01 by rototophe.
22 Mar 2013 06:45 #7990 by Lars
Replied by Lars on topic Solo Pro 125 finetuning
thx Rototophe, much appreciated. I was guessing on gear/ch5, but got the SP125 bnf with no j6pro transmitter or manual. Will go with your start settings !
Time to create page: 0.223 seconds
