Blade Nano CP X - Beginner Settings
- Tom Z
16 Apr 2013 22:57 - 15 Feb 2014 23:29 #8993
by Tom Z
Blade Nano CP X - Beginner Settings was created by Tom Z
UPDATE: 5/13/13
I have updated all the models which have the same name as before.
* Notice of Ch 3 being 0 not -100 has been corrected.
* DSM2 has been changed to DSMX.
Normal: 0% 40% 60% 80% 100%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Lower Pitch Travel Adjustment to make the heli more tame.
- Low dual rates and positive expo to tame the heli down.
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
Model 5 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 5-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 5 instead.
Model 44 is for deviation firmware v3 and the Devo 8/8S/12.
Model 45 is for deviation firmware v3 and the Devo 10.
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:29 by Tom Z.
Time to create page: 0.238 seconds
Model Configs
- Blade Nano CP X - Beginner Settings
