Blade Nano CP X - Standard Settings
- Tom Z
16 Apr 2013 23:21 - 15 Feb 2014 23:29 #8994
by Tom Z
Blade Nano CP X - Standard Settings was created by Tom Z
UPDATE: 5/13/13
I have updated all the models which have the same name as before.
* Notice of Ch 3 being 0 not -100 has been corrected.
* DSM2 has been changed to DSMX.
Normal: 0% 40% 60% 80% 100%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Model 6 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 6-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 6 instead.
Model 48 is for deviation firmware v3 and the Devo 8/8S/12.
Model 49 is for deviation firmware v3 and the Devo 10.
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:29 by Tom Z.
Time to create page: 0.125 seconds
Model Configs
- Blade Nano CP X - Standard Settings
