Mix to Throttle
28 Apr 2013 14:31 #9311 by fletch3d
Mix to Throttle was created by fletch3d
Hey Guys,
I am trying to setup a mix to throttle using the gear switch. I fly using a governer throttle on flight modes 30, 70, 100. I use the gear switch to get the throttle to see 0 so that it will arm the esc. I am not sure how to do this in the deviation setup?
29 Apr 2013 21:52 #9349 by RandMental
Replied by RandMental on topic Mix to Throttle
I am not sure if you mean mix to throttle in the traditional sense or use a mixer page in deviation to force the throttle to zero when gear is active?
If the latter, then have a look at how Tom Z implemented Throttle hold in his models, you could do the same using Gear.
29 Apr 2013 22:29 #9353 by sbstnp
Replied by sbstnp on topic Mix to Throttle
Using a complex mixer with 2 pages is the easiest. But, I'm not sure what you mean when say zero throttle. In Deviation 0 means middle, -100 is the lowest position.
Anyway, on THR channel switch the mixer type to complex and add this on page 2:
Switch: Gear1
Type: replace
Curve: Fixed
Scale: -100
or
Scale: 0
You can also leave the scale as it is and change the offset.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
29 Apr 2013 23:05 #9355 by fletch3d
Replied by fletch3d on topic Mix to Throttle
Yes.. you are correct I meant -100. Thank you for your response, it worked perfectly..
Time to create page: 0.133 seconds
