Align Trex 250 DFC 3GX using DSM2
- thwaitm
03 May 2013 14:57 - 03 May 2013 14:58 #9506
by thwaitm
Align Trex 250 DFC 3GX using DSM2 was created by thwaitm
This is my model.ini for a Align 250DFC with 3GX and DSM2 Orange satellites.
I've not flown it much as I have found out my ESC is weak but it can hover.
3GX is mounted as per the manual, plugs forward, upside down in the belly behind the rudder servo.
Things to check on your model are:
SWASH MIX values for ELE, AIL and COL
GYRO values - I have a wag which is causing me to need a low gyro gain setting
PIT curves - they are all the same NORM/ST1/ST2/TH
THRO curves - quick ramp up in NORM, shallow 90%V in ST1, 100% in ST2
DR/EXPO and set for ELE & AIL tune to your needs
Last edit: 03 May 2013 14:58 by thwaitm.
- bruiser
09 Jun 2013 14:11 #10732
by bruiser
Replied by bruiser on topic Align Trex 250 DFC 3GX using DSM2
I just apply your model.ini but I have found out that the pitch channel and elevator channel has swapped. Unfortunately, I don't know how to swap them back. My tx is mode 1.
My config. is a only bit different from yours. Mine is Trex 250 DFC 3GX, Devo 8s. I am using Spektrum DSM2 satellite rx connected directly to the 3GX.
Would you mind enlightening what I should do to swap the channels back.
Sorry for my bad English.
- thwaitm
21 Jun 2013 16:23 #11204
by thwaitm
Replied by thwaitm on topic Align Trex 250 DFC 3GX using DSM2
Did you work it out or do you still want me to take a look?
Time to create page: 0.204 seconds
Model Configs
- Align Trex 250 DFC 3GX using DSM2
