Walkera V450D01 rx2702v-d devo 8s
- hellboy
06 May 2013 20:15 #9627
by hellboy
Walkera V450D01 rx2702v-d devo 8s was created by hellboy
Hi
frnds
need help from you guys...regarding my walkera v450d01 setup with RX2702V-D
with my devo8s transmitter.i bought this heli as bnf set.but i am not able to set it properly...every time when i tried to lift up heli is spinning..so fast
as i am not prof..haveing hard time to find the problem...please help
Thank you ( sorry for my bad english)
frnds
07 May 2013 04:28 #9642
Replied by rbe2012 on topic Walkera V450D01 rx2702v-d devo 8s
It looks like your gyro direction is wrong so it moves the tail servo to the wrong side. The tail shall be corrected but the error will be improved instead. Did you check this?
There are gyros where you can not change the direction. Then you can moubt it upside down.
- RandMental
07 May 2013 10:42 #9658
by RandMental
Replied by RandMental on topic Walkera V450D01 rx2702v-d devo 8s
- hellboy
07 May 2013 11:00 #9660
by hellboy
Replied by hellboy on topic Walkera V450D01 rx2702v-d devo 8s
hello,
thanks for the help frnds..after turning on the gyro helicopter is not spinning anymore...but now another problem .after giving thorottel
heli is not in control.So when I fly and set the throttle back to zero the heli is pushed violently of the ground.thorottel is on zero positon..but blade are still spinning and then i have turn the transmitter off..
this happen never to me...what i am doing wrong?
Thanks for your help
- sbstnp
07 May 2013 11:02 #9661
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Walkera V450D01 rx2702v-d devo 8s
Sounds like you're in IDLE UP. This is a mode where you have constant (or almost) headspeed and control the heli by varying the pitch.
Check your FMODE switch and post your model .ini file please.
Devo 10 + 4in1
- hellboy
07 May 2013 11:27 #9662
by hellboy
This is my DEVO 8S setup.
Swash Type: 3 Servos 120°C
Reverse switch
Elevator : Normal
Aileron: Reverse
Throttle: Normal
Rudder: Reverse
Gear: Normal
Pitch: Normal
Gyro: Normal
Gyro Sensor
Mode: Manaul
Switch: MIX SW
Pos1: 70%
Pos2: 50%
Pos3: 50%
Swash Mix
Aileron: + 70%
Elevator : +70%
Pitch: +80%
fmode normal
heli pushed violently of the ground
Reverse switch
Elevator : Normal
Aileron: Reverse
Throttle: Normal
Rudder: Reverse
Gear: Normal
Pitch: Normal
Gyro: Normal
Gyro Sensor
Mode: Manaul
Switch: MIX SW
Pos1: 70%
Pos2: 50%
Pos3: 50%
Swash Mix
Aileron: + 70%
Elevator : +70%
Pitch: +80%
fmode normal
07 May 2013 12:15 #9663
This is what you have configured. It would be easier for us to see the model.ini-file because in your description are missing some values, esp. anything about mixing.
- hellboy
07 May 2013 13:54 #9668
by hellboy
AS I am new in this hobby..i dont know how to find initial file? you mean from my transmitter? no idea.
is this pitch problem? cause i can lift the helicopter but..pushed violently of the ground and iam so nervous now to test it..i dont want to crash it
- sbstnp
07 May 2013 13:59 #9669
by sbstnp
One question before going further, are you running Deviation? I mean the DFU file downloaded from this site and flashed on your transmitter.
Devo 10 + 4in1
Spektrum Dx9
hellboy wrote: AS I am new in this hobby..i dont know how to find initial file? you mean from my transmitter? no idea.
Devo 10 + 4in1
- hellboy
07 May 2013 14:03 #9671
by hellboy
NO i have devention 8s transmitter from my old helicpoter 4f200lm
i did'nt downloaded any file from this site? or any flashed file.
my my transmitter hardware ver.2.0 software ver.0.8B library ver.0.0.5
thanks for your support
07 May 2013 15:13 #9674
Sorry, but this forum is about a new developed firmware for die Devo transmitters called "deviation". This new software and the original Walkera firmware are not interchangeable nor the model configs are.
I think you should try to get answers in other forums (e.g. rcgroups) because most of us have not used the original firmware since a long time.
Thank you sbstnp for asking the right question...
- RandMental
07 May 2013 16:10 - 07 May 2013 17:23 #9676
by RandMental
Last edit: 07 May 2013 17:23 by RandMental.
- sbstnp
07 May 2013 16:51 #9677
by sbstnp
That's so true, I cannot even remember how the stock firmware looks
Devo 10 + 4in1
Spektrum Dx9
rbe2012 wrote: I think you should try to get answers in other forums (e.g. rcgroups) because most of us have not used the original firmware since a long time
Devo 10 + 4in1
- hellboy
07 May 2013 17:07 #9679
by hellboy
Thanks alot for all your support frnds
- sbstnp
07 May 2013 17:38 #9681
by sbstnp
If you ever want to go Deviation way we'll be able to help you.
Devo 10 + 4in1
Spektrum Dx9
Devo 10 + 4in1
- saad khan
20 Jan 2015 20:50 #27903
by saad khan
Replied by saad khan on topic Walkera V450D01 rx2702v-d devo 8s
I ve 2702 just buy now but its aile gyro reverse switch is not working. What should I do now,,,
- Zaphod
25 Jan 2015 12:11 #28014
by Zaphod
Replied by Zaphod on topic Walkera V450D01 rx2702v-d devo 8s
Check out this video for setting up the RX2702V -http://youtu.be/BUnak6YDdGc
This is part 1. Watch part 2 as well.
Time to create page: 1.213 seconds
Model Configs
- Walkera V450D01 rx2702v-d devo 8s
