Ladybird V1 (Led on Aux ?)
12 May 2013 20:02 #9900 by Franck
Ladybird V1 (Led on Aux ?) was created by Franck
bonjour a tous, je recherche comment connecter des leds sur la sortie AUX, de ma ladybird V1. Et aussi comment l'activer dans DEVIATION.
Hello everyone, where can i connect the leds in AUX connector, on my ladybird V1. And also, how to enable it in DEVIATION.
Thank you
12 May 2013 21:02 #9901 by ledfreak3d
Replied by ledfreak3d on topic Ladybird V1 (Led on Aux ?)
there is one connector on the ladybird board where youu can connect a led to and controll it from the tx
its the bind plug connector but it uses the middle pin and one of the outside pins.
have to check on my ladybird
19 May 2013 07:31 #10107 by Franck
Replied by Franck on topic Ladybird V1 (Led on Aux ?)
I connected as the picture, then I tried the radio but it does not work ... :(
Could you send me your menu *. Ini
19 May 2013 12:02 #10109 by ledfreak3d
hi frank have to check mine
havent been using them for some time
19 May 2013 22:56 #10117 by MiG_31
Replied by MiG_31 on topic Ladybird V1 (Led on Aux ?)
Salut, Franck!
It's my photo you have posted. I'm including my model.ini file, where it works. In my config file, you turn led on/off with GEAR switch. (5th channel ). I'm using devo6. Hope this helps.
20 May 2013 05:00 #10127 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Ladybird V1 (Led on Aux ?)
Curious if anyone knows if other Walkera RX's work like this, eg. the Super CP? It's got the same two spare connectors...
20 May 2013 06:50 #10128 by Franck
Merci MiG_31 ! J’ai essayé ton model.in et cela ne fonctionne pas non plus sur le connecteur auxiliaire. Par contre cela fonctionne sur le connecteur de mise à jour (voir photo) comme avec mon menu.
Le problème, en utilisant le connecteur de mise à jour, est que je n'arrive pas à démarrer ma ladybird avec mes 4 leds. Si je mets une led s'est bon...
Bref j'ai trouvé la solution pour utiliser 4 leds avec le connecteur de mise à jour, je passe par un transistor PNP et cela fonctionne. La mise en route des leds est toujours sur le canal gear.
Ne pourrait-il pas y avoir des ladybird avec le connecteur auxiliaire diffèrent ?
sorry for the translation
Thank you MiG_31 ! I tried your model.in and does not work on the auxiliary connector. It works on the connector update (see photo) as with my menu.
The problem using the connector upgrade is that I can not start my ladybird with my 4 leds. If I put on LED is good ...
Anyway I found the solution for use with 4 leds connector update, I go through a transistor PNP and it works. The start of the LEDs is always on the gear channel.
Could there not have ladybird with the auxiliary connector differ?
20 May 2013 08:58 #10133 by MiG_31
Franck
Are you getting 3.7v on connectors that I indicated as + - with tx turned off? When in binding mode, my ladybird has 3.7v there. If not - we probably have different pinout. If yes- It is software related (another channel, another switch)
20 May 2013 12:43 #10145 by Franck
MiG_31 wrote: Franck
When my Tx turned off, i have 3,7v on + and -
20 May 2013 13:23 - 20 May 2013 14:04 #10150 by MiG_31
Then you should find out on which channel in your radio is this aux channel.Have you tried mix switch with my config file?
You should experiment and find out, which channel turns your led on with negative value. Just to try, put negative values into channel 5, 6, 7, 8 and you'll find out with which of them will turn leds on. Then you will simply add a switch to that channel. Use channel monitor to view actual output of each channel.
Last edit: 20 May 2013 14:04 by MiG_31.
20 May 2013 13:36 #10152 by Franck
MiG_31 wrote: Then you should find out on wich channel in your radio is this aux channel.Have you tried mix switch with my config file?
You should experiment and find out, wich channel turns your led on with negative value. Just to try, put negative values into channel 5, 6, 7, 8 and you'll find out with wich of them will turn leds on. Then you will simply add a switch to that channel. Use channel monitor to view actual output of each channel.
Canal GEAR is ok
20 May 2013 15:07 #10154 by MiG_31
Franck
I think your channel order is different from mine. If I am right, your led will work in aux socket with gear switch with attached ini file. I suppose, you were adjusting gyro with your GEAR switch. Also, if i am right, your onboard ladybird's led changed color, when you were using upgrade socket.
20 May 2013 15:14 #10155 by Franck
YES ! "your onboard ladybird's led changed color, when you were using upgrade socket"
29 May 2013 19:03 #10413 by Franck
Here is my QR Ladybird with LED
16 Nov 2014 22:35 - 22 Nov 2014 20:01 #26435 by ursus69
Replied by ursus69 on topic Ladybird V1 (Led on Aux ?)
First...sorry for my bad english... :( , and second, sorry for restart the topic..
I have a Ladybird V1 & Devo7E with Deviation..
I want to control the led with the switch....and I 'm going crazy...
My Devo7E only have FMode Switch (I use for change fly mode (red/green) and HOLD switch
What need to do to control the LED in AUXport with the HOLD switch in my Devo7E?
I try with yours models.ini....but my Devo don't have GEAR switch...and don't work for me... :(
Someone can help me?
Last edit: 22 Nov 2014 20:01 by ursus69.
22 Nov 2014 20:02 #26524 by ursus69
Any suggestions, please?
22 Nov 2014 20:15 #26525 by FDR
Replied by FDR on topic Ladybird V1 (Led on Aux ?)
Simply add a simple mixer to the Ch5, set the source to HOLD1 and select the min/max function.
24 Nov 2014 20:36 - 25 Nov 2014 23:53 #26562 by ursus69
Thank you FDR!
It works, but in the update connector, not at auxiliary connector....and when I connect the battery to ladybird, it start bindind mode.... :(
And only works 2 of the 4 smd leds that I installed on ladybird...
Any idea?
Last edit: 25 Nov 2014 23:53 by ursus69.
26 Nov 2014 20:57 #26591 by ursus69
I've tried with tho others channels...but no work...
Any idea to work in the aux connector?
Thank you!!
01 Dec 2014 19:18 #26712 by Franck
ursus69 wrote: I've tried with tho others channels...but no work...
Thank you!!
As tu mis a jour le firmware ? par defaut fonctionne pas.
Have you updated the firmware? Default not.
Time to create page: 1.175 seconds
