Model config of Walkera V400D02 ?
- sven
19 Jun 2013 11:25 #11114
by sven
Model config of Walkera V400D02 ? was created by sven
does anyone use Deviation in combination with Walkera V400D02 and Devo10?
Which model config do you use (e.g. Master CP, standard CP, beginner CP)?
Do you have a special model config for V400D02?
Thanks in advance.
Best regards,
Sven
Thanks in advance.
Best regards,
Sven
- Tom Z
17 Jul 2013 23:56 - 18 Jul 2013 00:05 #12313
by Tom Z
Replied by Tom Z on topic Model config of Walkera V400D02 ?
I downloaded the Walkera V400D02 user manual.
Also the manual shows the heli setup with the WK-2603 transmitter.
All the models I have posted on this site are for a 3 or 6 axis Rx
and the Swash setting is for 1 Servo Normal.
To use any of them for your V400D02 you would need to change the protocol from Devo to WK2601 or WK2801 (I'm not sure which one) and you would need to set the Swash Type for 3 Servos (120* E-P-A).
The V400D02 servo settings are the same as the models I have posted.
All the other setting should work fine also.
Standard CP, Beginner CP, Master CP models should all work with a couple of changes.
Last edit: 18 Jul 2013 00:05 by Tom Z.
Time to create page: 0.093 seconds
Model Configs
- Model config of Walkera V400D02 ?
