Nano QX from Horizon
- Mr-Ferret
27 Jun 2013 23:29 #11475
by Mr-Ferret
Nano QX from Horizon was created by Mr-Ferret
i am looking for the settings for the new nano QX include switching from stabinity to agility mode.
Thank's
regards
Mr-Ferret
Thank's
regards
Mr-Ferret
- adabman
28 Jun 2013 04:29 #11486
by adabman
Deviation
1 TX to rule them all...
Replied by adabman on topic Nano QX from Horizon
I picked up one of these today for my GF, but got it home and 1 motor doesnt work
Ill try and replace it tomorrow then I can work on a model.ini
Deviation
- jason4207
02 Jul 2013 14:57 #11753
by jason4207
Replied by jason4207 on topic Nano QX from Horizon
Here is what I'm using courtesy of Daryoon.
model10 is setup for 80/100 DR, and model12 is setup for 70/125 DR.
Icon is also in there.
- Mr-Ferret
02 Jul 2013 20:58 - 02 Jul 2013 20:59 #11775
by Mr-Ferret
Replied by Mr-Ferret on topic Nano QX from Horizon
Hello Jason4207,
thanks for the good job, but one question,
how can i switching from stabinity to agility mode?
sorry, i forgot, i have a Devo 8s, but your config works fine.
Last edit: 02 Jul 2013 20:59 by Mr-Ferret.
- Mr-Ferret
02 Jul 2013 22:03 - 04 Jul 2013 21:37 #11784
by Mr-Ferret
Hello all,
i found the solution, you can switch the mode by gear stick.
Last edit: 04 Jul 2013 21:37 by Mr-Ferret.
- adabman
02 Jul 2013 22:19 #11789
by adabman
Deviation
Thanks for this. I have yet to return my nano .. Nice to know when I do this is already done.
Deviation
- Mr-Ferret
04 Jul 2013 21:42 #11913
by Mr-Ferret
Now I have created an icon, I hope that is the configuration done.
Have fun!
Have fun!
- fredbotton
05 Jul 2013 20:41 - 05 Jul 2013 20:43 #11981
by fredbotton
Replied by fredbotton on topic Nano QX from Horizon
Damn, I can't make any of the .ini work with my Nano QX. I get no connexion between Devo 8S & Nano.
I made it work using an old Blade mQX .ini, but can't change to agility mode with it
Any clue ?
Any clue ?
Last edit: 05 Jul 2013 20:43 by fredbotton.
- Mr-Ferret
05 Jul 2013 22:59 #11993
by Mr-Ferret
Well, i have a Devo 8, and the config Model11 above works vary well.
The link takes at the first time a little bit longer, but after the second time it has always worked for me.
regards
regards
- fredbotton
06 Jul 2013 05:34 - 06 Jul 2013 06:14 #12002
by fredbotton
Can you describe how you make it sync? I must have missed some step
Edit: I've managed to link the QX, but I had to specify DSM2 & Helicopter (was set to None & Plane) in the settings. Gear switch does not do anything. Could it be because I'm still running Deviation FW 2.10?
Last edit: 06 Jul 2013 06:14 by fredbotton.
- Mr-Ferret
07 Jul 2013 20:42 - 07 Jul 2013 20:59 #12051
by Mr-Ferret
Hello fredbotton,
i have follow configuration:
Modeltype: Airplane
Protocol: DSMX
Channals: 7
TX Power: 10mW
Fixed ID: nnnnnn
1-THR THR Simple
2-AIL AIL Simple
3-ELE ELE Simple
4-RUD RUD Simple
5-GEAR None
Ch6 Gear0 Simple (important for switch from stability to agility)
Regards
Modeltype: Airplane
Protocol: DSMX
Channals: 7
TX Power: 10mW
Fixed ID: nnnnnn
1-THR THR Simple
2-AIL AIL Simple
3-ELE ELE Simple
4-RUD RUD Simple
5-GEAR None
Regards
Last edit: 07 Jul 2013 20:59 by Mr-Ferret.
- fredbotton
08 Jul 2013 13:11 #12083
by fredbotton
Okay, I finally made it work properly...
Do you know if there's a way to change the agility mode to a more nervous mode? Using the Horizon Hobby MLP4dsm radio, pushing one of the sticks changes mode, the other switches from 70% to 100% and back...
- Mr-Ferret
08 Jul 2013 21:38 #12110
by Mr-Ferret
the QX has 2 modes, stability and agility.
if the stability mode activ, the LED is blue, in agility mode, the LED is red.
i don't have a MLP4dsm radio, so i can't say what is to do to change the mode.
- fredbotton
09 Jul 2013 06:47 - 09 Jul 2013 06:48 #12121
by fredbotton
Well, that basic radio gives 2 options:
- depressing left stick alternates stability and agility modes (that's the one you mention). Changes LED from blue to red. My guess is that it operates or removes Safe technology/stabilization.
- depressing right stick alternates 70% dual rate and 100% dual rate. No change in LED.
You can cumulate stability & 70% (slow device), agility & 100% (rocket!).
On my deviated Devo 8S I've somehow managed to put modes on the gear switch (have to switch and switch back though to make it work properly), and rates on the FMode. 0 is 50% (non existing mode, very slow to operate in very small spaces), 1 is 70%, 2 is 100%. Not sure about what I've done exactly, I may have added bugs in the process. I can upload the .ini resulting file if required!
Last edit: 09 Jul 2013 06:48 by fredbotton.
- Mr-Ferret
09 Jul 2013 12:52 #12138
by Mr-Ferret
yes, please upload your ini and put it in this forum.
i would like test it, maybe it is better as the ini from myselsf.
- fredbotton
09 Jul 2013 13:04 - 09 Jul 2013 14:36 #12139
by fredbotton
Here it is. So Fmod 0/1/2 allows rates 50%/70%/100%, and Elev D/R switches controls stability/agility (need to switch from 0 to 1 then 0 again to change mode - sorry dunno how to make 0 stability and 1 agility).
I'm using it with a Bnf Nano QX and Devo 8s...
Last edit: 09 Jul 2013 14:36 by fredbotton.
- Mr-Ferret
09 Jul 2013 21:03 #12152
by Mr-Ferret
sorry, have you test you're own config?
Fmode is not configured, nothing to change the rate.
but look the config in the appendix.
- fredbotton
10 Jul 2013 06:51 #12162
by fredbotton
Ooops, wrong .ini uploaded, you are right...
Sorry, I'm reuploading.
And trying out yours as well!
- fredbotton
10 Jul 2013 16:49 #12166
by fredbotton
I haven't been able to reproduce the quick flips I'm doing with a Ladybird or Hubsan X4 with the Nano so far, only long wide loops.
I thought that was impossible, until I saw that video :http://www.youtube.com/watch?feature=player_embedded&v=n_XIqk_-Q5M
See at the end, the guy from HH does several quick flips.
Looks like I still need some tweaking in the .ini file to be able to do that! Or is it my piloting skills?
- jason4207
10 Jul 2013 22:51 #12170
by jason4207
Did you max out the rates?
Time to create page: 0.416 seconds
Model Configs
- Nano QX from Horizon
