Walkera V200D03
02 Jul 2013 20:58 #11776 by Kregore
Walkera V200D03 was created by Kregore
Huhu there
can someone create a model.ini for the V200D03 on Devo8s
Iam absolutley noob in configuring the Remote Control
Thx for help
Kregore
16 Jul 2013 19:00 #12271 by Nightshift
Replied by Nightshift on topic Walkera V200D03
Hi every one!
I also got a V200 D03 and a devo8s with the deviation on it
can somebody help me with the configuration of that model
i'm not used to config.
I saw a other post about it but not shure if it's working or not
Thank you!
16 Jul 2013 23:45 - 17 Jul 2013 00:16 #12276 by Tom Z
Replied by Tom Z on topic Walkera V200D03
You can download one of my models below and make the following changes.
Reverse the servos for ELEV and RUDD
See my picture.
Before you fly make sure the servos are working in the correct direction.
Also make sure the RUDD is working in the correct direction. Give a little throttle when the hei is on the ground and give some rudder and check that it is working in the correct direction.
I don't have the V200D03 or I would make a model for you and test fly it.
Walkera CP Helicopters - Beginner Settings
www.deviationtx.com/forum/model-configs/...rs-beginner-settings
Walkera CP Helicopters - Standard Settings
www.deviationtx.com/forum/model-configs/...rs-standard-settings
Walkera Master CP - 3D Settings
www.deviationtx.com/forum/model-configs/...aster-cp-3d-settings
Last edit: 17 Jul 2013 00:16 by Tom Z.
17 Jul 2013 00:13 #12278 by Crash Survivor
Replied by Crash Survivor on topic Walkera V200D03
Tom Z will these work on deviation V3?
17 Jul 2013 00:27 #12279 by Tom Z
I made models for the v3 also. In the description for all the models I posted look for something like this below which have a model number, firmware version, and which transmitter you can use it on. A couple models are also made for the Devo 6S thanks to JJ1984 for helping me on these.
Model 14 is for deviation firmware v2.1 and the Devo 8/8S/12.
Model 15 is for deviation firmware v3 and the Devo 8/8S/12.
Model 6 is for deviation firmware v2.1 and the Devo 10.
Model 7 is for deviation firmware v3 and the Devo 10.
See my post here for the Devo 6S model.
Time to create page: 0.131 seconds
