- DJI Naza + GPS with R710 or R910 RX on DBUS output
- goebish
- NRF Weirdo
23 Aug 2013 10:09 - 23 Aug 2013 17:10 #13176
by goebish
DJI Naza + GPS with R710 or R910 RX on DBUS output was created by goebish
Attached is my profile (Devo 10), don't forget you'll still have to calibrate sticks and other channels in the assistant before you can use it! That's better to do it with a blank profile, don't worry if aileron & elevator channels are swapped, that's normal (weird channels order on DBUS), calibrate like that, it is fixed in my profile.
Everything works, GPS / ATTI / Manual / IOC / RTH (on switch and on signal loss) and last but not least it uses the DBUS port of the R710, requiring only 1 servo cable going from the RX to the Naza for the 7 channels
If you want the failsafe/RTH at signal loss to work you'll have to bind the RX in Preset Failsafe mode (read the OrangeRX documentation) while the TX is set to more than 10% throttle and failsafe/RTH is enabled (AILE D/R 1).
This profile is for Devo 10 / OrangeRX DSM2 R710 or R910 on DBUS / Naza M v1 or v2 + GPS (DBUS input is on X2 connector):
Elevator & Rudder channels need to be reversed in Naza assistant.
RUDD D/R 1: throttle cut
FMODE 0: GPS
FMODE 1: ATTI
FMODE 2: Manual
AILE D/R 1: Failsafe / Return To Home (overrides FMODE, to regain control reset the AILE D/R switch to 0 then switch to any FMODE other than the one you were using when you entered RTH mode.... that's weird but that's how the Naza works. Make sure your home position has been correctly set before using this mode !!!)
MIX 0: IOC Off
MIX 1: IOC Course Lock
MIX 2: IOC Home Lock
AUX4: X1 channel, can be assigned to various functions in the assistant: gimball pitch manual control speed, gains...
8mn countdown timer on throttle.
FMODE 0: GPS
FMODE 1: ATTI
FMODE 2: Manual
MIX 0: IOC Off
Last edit: 23 Aug 2013 17:10 by goebish. Reason: added icon file
- drahdiwaberl
05 Apr 2014 08:01 #22142
by drahdiwaberl
very new to deviationtx, currently having a hard time getting a naza v2 with AR6200 to work, but still this seems to have some good info for me and i'm considering getting an R710 for it's DBUS alone..
you're mentioning a weird channel order on DBUS - but isn't this rather dictated by the DSM-protocol? could you list the channel order?
also new info for me is one should calibrate sticks in naza tool with a blank profile on tx - any background on that? currently am stuck with one channel not getting negative values to the naza which might just be a calibration thing.. gotta give it a try the way you mentioned.
will load this to see if i can learn some more from it.
thanks.
Replied by drahdiwaberl on topic DJI Naza + GPS with R710 or R910 RX on DBUS output
goebish wrote: Attached is my profile (Devo 10), don't forget you'll still have to calibrate sticks and other channels in the assistant before you can use it! That's better to do it with a blank profile, don't worry if aileron & elevator channels are swapped, that's normal (weird channels order on DBUS), calibrate like that, it is fixed in my profile.
thanks.
Time to create page: 0.186 seconds
Model Configs
