- My Align T-Rex 450 + RX1002 + Devo 10 config file
- billmester
25 Aug 2013 08:47 #13253
by billmester
My Align T-Rex 450 + RX1002 + Devo 10 config file was created by billmester
This is the config file I am using for my Airwolf, having a T-rex 450SE inside with a DEVO 10. It might not be the most professional config, but am flying this daily, so it works
Enjoy.
If you have some improvement ideas, please share
RX1002:
ELE: elevon servo: rear (outside on the left)
AIL: aileron servo: front, bottom.
THR: ESC
RUDD: Gyro
GEAR: no connect
AUX1: pitch servo: front, upper.
AUX2: Gyro gain
AUX3: no connect
AUX4: Gear servo (easier to reach...)
AUX5: no connect
Functions:
- 3 filght modes, curves by the T-rex manual FMOD
- "Sticky" throttle hold, RUDD D/R + Throttle lever to bottom first
- Slo mo gear for the Airfox body, GEAR
- Hover pitch adjust, ELEV D/R + AUX4
- 3 gyro sensitivity, 2 fixed Head hold, higher and lower, 3rd is live pot variable for setup, both rate + HH mode, MIX, AUX5
- 1 stop watch + 1 countdown, throttle start and AILE D/R reset
Screen:
- 4 trims
- left: stopwatch + count down
- right, from top: cyclic, throttle, gyro gain
Enjoy.
RX1002:
THR: ESC
RUDD: Gyro
GEAR: no connect
AUX2: Gyro gain
AUX3: no connect
AUX5: no connect
Functions:
Screen:
- 4 trims
- Diaz
- Keep flying!
03 Nov 2013 23:14 #15305
by Diaz
Erik
Replied by Diaz on topic My Align T-Rex 450 + RX1002 + Devo 10 config file
Can anyone help me set up a blade 300 x with a 3gx Fbl system? I needed bad newbie to this devation program.. Want to learn it bad . This is greatest thing ever made for the rc community !! God bless you guys !!
Erik
Time to create page: 0.099 seconds
Model Configs
