lady bird help please !
- steven
06 Sep 2013 23:13 #13619
by steven
lady bird help please ! was created by steven
ok i lost my lady bird so i bought all the parts to build a new one , and the gyro is making it do flips , it just wants to flip to the right , all the motor arms and plugs are hooked up the right way , i have a devo 4 transmitter , could the new receiver be bad ?
- Hexperience
07 Sep 2013 00:07 #13620
by Hexperience
Replied by Hexperience on topic lady bird help please !
All the props are on the correct way and spinning the correct way?
- steven
07 Sep 2013 01:02 #13621
by steven
Replied by steven on topic lady bird help please !
ya , there definitely the right way
07 Sep 2013 08:12 #13627
Replied by FDR on topic lady bird help please !
Does the board point in the right direction?
It would have the same effect as if you mess up the motors and/or props...
- steven
09 Sep 2013 00:14 #13653
by steven
yes the board is right and the props and motors are all the right way , and it stills tries to flip to the right
09 Sep 2013 04:06 #13654
Do all the motors spin freely?
Do they stop at once?
09 Sep 2013 04:40 - 09 Sep 2013 04:41 #13655
Replied by vlad_vy on topic lady bird help please !
If my Ladybird has erratic behaviour, usually I fix that by reset Fixed ID.
Last edit: 09 Sep 2013 04:41 by vlad_vy.
- steven
09 Sep 2013 09:33 - 09 Sep 2013 09:34 #13659
by steven
yes thay spin freely
how do i reset the fixed id
Last edit: 09 Sep 2013 09:34 by steven.
09 Sep 2013 09:44 #13660
Connect bind plug to AUX2 connector, power on Ladybird, when indicator start to flash, power off and disconnect bind plug.
- steven
09 Sep 2013 09:53 #13662
by steven
tried that still no luck
i think the gyro is bad
or the transmitter needs to be reset , devo4
- steven
09 Sep 2013 19:52 - 09 Sep 2013 21:11 #13670
by steven
ok so i figured this out , the back (rear)right motor is spinning the right way (just like the manual , but for some reason it blows air up ? , i swapped the motor and it still dose the same thing ( i have spare motors) so i flipped the motor upside down and it almost flies the right way , very strange
and now after it binds to the transmitter the transmitter continues to blink?
so my friend just fount my original lady bird , and its doing the same thing (it used to fly just fine) so i reversed the wires on the moter that was blowing air up , and now they all create lift , but it want to flip to the left , wtf , could the transmitter be bad ? i have no clue ...............
Last edit: 09 Sep 2013 21:11 by steven.
- stevecox
- Keep swinging
10 Sep 2013 04:04 - 10 Sep 2013 04:07 #13672
by stevecox
Adelaide
Replied by stevecox on topic lady bird help please !
You have the props on incorrectly. Start with getting the motors spinning in the right direction as per the manual, then check that the prop you put on each motor will create lift from the direction it is supposed to spin - should have been the first thing you checked, not just the direction of the motor - prop needs to be correct as well eish
Looking at your photo it looks like you have 2 of the same direction type prop (the orange ones) which is wrong. You need one for RH direction and one for LH direction, check the black props for what I mean.
Adelaide
Last edit: 10 Sep 2013 04:07 by stevecox.
10 Sep 2013 04:33 - 10 Sep 2013 04:41 #13675
Seems you have wrong motor direction. Any QR has 2 clockwise and 2 counterclockwise motors.
Front left = clockwise motor, red & blue motor wires (along motor can)
Front right = counterclockwise motor, white and black motor wires
Rear left = counterclockwise motor, white and black motor wires
Rear right = clockwise motor, red & blue motor wires
Clockwise motor, red & blue motor wires along motor can
Last edit: 10 Sep 2013 04:41 by vlad_vy.
- stevecox
- Keep swinging
10 Sep 2013 19:11 #13689
by stevecox
Adelaide
vlad_vy, in his pictures it seems he has 2 x counter-clockwise orange props, even with motor direction correct, like this it will not fly.
Adelaide
- steven
11 Sep 2013 01:00 #13693
by steven
ty all , i had the props on wrong , flys great again !!!
Time to create page: 1.031 seconds
Model Configs
- lady bird help please !
