Wltoy V959 upgraded v222 and DEVO7e with nrf24l01
28 Nov 2013 11:23 #15962 by Sascha121985
i would like to by a V959 up. v222 with the v202 protocol.
I have just installed the nrf24l01 to my Devo 7e and control with this the JD-185.
Now my question, is it possible that i can control the light, cam,... with the devo 7e?
I need to install switch? Or can i control this with the trim buttons?
Which firmware must be installed?
Thanks in advance.
Greats from Germany
Sascha
28 Nov 2013 18:50 #15993 by SeByDocKy
Left Vertical Switch Up - Ch7 Momentary - Camera/AutoMissle/HoistA
Left Vertical Switch Down - Ch8 Momentary - Video/Missle/Sprayer/HoistB
Left Horizontal Switch Right - Ch5 Toggle - Toggle LEDs On/Off
Left Horizontal Switch Left - N/A
TH - Ch6 - Flips
FMOD - DualRates
File Attachment:
File Name: V222Trim.zip
File Size:1 KB
04 Dec 2013 08:48 #16261 by Sascha121985
Replied by Sascha121985 on topic Wltoy V959 upgraded v222 and DEVO7e with nrf24l01
Thank you, for your File.
One Question a least.
Have have to rebind the v222 every time
when i cut the Lipo off.
Is it normal?
With my JD-185 it will automaticly bind.
04 Dec 2013 09:21 #16262 by yidc
hello Sascha,
are u flying your Devo 7e + nrf24l01 w/ JXD JD-385? or really JD-185? (thought it's somehow a typo)
2 questions:
1. How do you get auto-binding? I have to rebind my JD-385 everytime, which is very troublesome.
2. What's your control range? My Devo 7e is using default 150mW + nrf24l01 (WITHOUT PA + LNA), I only got 5m or something... can only fly indoor right now :(
04 Dec 2013 09:56 #16263 by Sascha121985
Hello yidic,
yes it is the JD-385. I bind it one time in the Modelconfig and then it will rebind every time automaticly.
At first i had some NRF24l01 without PA and the range were round about 7 Meters.
Now with the PA and LNA it is over 15 Meters. In this range it is not possible to check the orientation of the JD-385.
And sorry for my english ;-)
Sascha
04 Dec 2013 10:34 #16264 by yidc
Thanks for the clarification!
I'm definitely gonna get a NRF24L01 with PA then.
What do u mean by "I bind it one time in the Modelconfig"? Do u mean fixed ID?
04 Dec 2013 10:45 #16266 by SeByDocKy
Sascha121985 wrote: Hello yidic,
Sascha
I got more than 100 meters easely with my nRF24L01+PA with any of my quad
(V252, V262, JD 385)
04 Dec 2013 12:02 #16268 by Sascha121985
Ok. What for a antenna do you use?
Do you have to rebind it every time?
04 Dec 2013 13:05 #16272 by yidc
SeByDocKy,
Thx for the info! I've already ordered a new nRF24l01+PA module to test out. Will update u
results later. ;)
Sascha,
My old nRF24l01 does not come w/ an antenna. Using default Tx Output power.
Yes, I have to press "Bind" every time I switch on my Devo 7e. It doesn't auto-bind my JD-385.
Do I need to set a Fixed ID?
04 Dec 2013 13:06 - 04 Dec 2013 13:39 #16273 by SeByDocKy
Sascha121985 wrote: Ok. What for a antenna do you use?
i ) I use this antenna ...
ii) Yes most of the time I have to rebind ...
Last edit: 04 Dec 2013 13:39 by SeByDocKy.
