3GX with Devo Rx601 and Orange615
21 Dec 2013 22:07 - 21 Dec 2013 23:35 #16908 by NoMaster
3GX with Devo Rx601 and Orange615 was created by NoMaster
i have a problem setting up 3gx with Rx601 or OrangeR615.
Binding, setting channels ... everything works fine.
BUT: i am not able to get the pitch work on all 3 servos :blink:
Tried swashplate 120 with all possible settings but the only servo moving is the pit-servo when giving pitch on channel 6 :(
Throttle/Ail/Ele/Rud are working as they should.
It seems that the swashmix is not working as it should?
Hopefully i am only to blind to see :blush:
P.S.: Devo10 with nightly of 21.12.2013 ... and sorry for my bad english.
Last edit: 21 Dec 2013 23:35 by NoMaster.
21 Dec 2013 22:10 #16909 by Hexperience
Replied by Hexperience on topic 3GX with Devo Rx601 and Orange615
I'm not positive about the 3gx but most fbl controllers do the mixing for you. Your swash type should be none.
21 Dec 2013 22:13 #16910 by NoMaster
Replied by NoMaster on topic 3GX with Devo Rx601 and Orange615
I have tried all kinds of types ... 120, 120x, none ... the behavior stays the same :(
21 Dec 2013 22:20 #16911 by Hexperience
yeah, I just looked it up... (I was on my phone when I replied last time). You want the swash type at 120. I don't have the manual for the 3gx, but does it have a swash setting? It sounds like the 3gx itself thinks you have a 1 servo or 90 degree swash plate.
21 Dec 2013 22:25 #16912 by NoMaster
As far as i know from the manual and how-to-vids, the 3gx wants a 120-swashplate ... so my problem seems to be that i am not able to give the 3gx what it wants to have !?
I have tried hours of settings.
Is the setting of swashplate saved, when leaving the menu ? or do i have to rebind each time i changed the settings ?
21 Dec 2013 22:27 #16913 by FDR
Replied by FDR on topic 3GX with Devo Rx601 and Orange615
If you need CCPM in the tx, load th 6ch heli template as a starting point, and set the swash to 120...
21 Dec 2013 23:27 #16915 by NoMaster
Thanks FDR :)
Starting with the template of the 6Channel Heli it works :woohoo:
Seems that the "cyclics" are needed ? I would like to understand that ...
but for this topic: solved :silly:
Thanks to this community and all the people working on this software !!! :cheer:
Time to create page: 0.067 seconds
