Walkera Master CP - Beginner Settings
- Tom Z
07 Jan 2014 02:23 - 30 Apr 2014 15:16 #18120
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Walkera Master CP - Beginner Settings was created by Tom Z
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Low Pitch Travel Adjustment to make the heli more tame.
- Low dual rates and positive expo to tame the heli down.
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
Model 10 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 10-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 10 instead.
I have test flown this model in my Devo 10.
Throttle Curve
Pitch Curve
Gyro Gain
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:16 by Tom Z.
- Rotorwash79
15 Feb 2014 19:24 #20322
by Rotorwash79
Replied by Rotorwash79 on topic Walkera Master CP - Beginner Settings
Will this model work in a devo 7? If not where could I find master / mini cp models for devo 7?
Any help is greatly appreciated,
Thank you
Thank you
- Tom Z
15 Feb 2014 22:52 - 16 Feb 2014 22:52 #20335
by Tom Z
Replied by Tom Z on topic Walkera Master CP - Beginner Settings
Hi, the model will fully work in the Devo 7e except for DR/EXPO.
Due to the Devo 7e has less switches than the other transmitters things happen if you use the other models not made just for the 7e.
There is one less flight mode and switch assignments will change.
Last edit: 16 Feb 2014 22:52 by Tom Z.
- olongapso
06 Apr 2014 21:03 #22178
by olongapso
Replied by olongapso on topic Walkera Master CP - Beginner Settings
hi guys, thanks for models.
I download these files, charged in my DEVO 10 and here is problem: there is not connection between radio and hely, even if I bind few times.
Maybe I make mistake during binding. suggestion?
- geyserbleu
21 Apr 2014 22:37 #22641
by geyserbleu
Replied by geyserbleu on topic Beginner Settings
Good morning,
I am in France and I have Airwolf 200SD3 with Devo8s V4. Could you help me for setting this héli with my Devo 8s please. I am beginner RC. I don't understand what is FMOD with 3 positions ? Thank you very much
regard
regard
- Tom Z
22 Apr 2014 00:33 - 22 Apr 2014 00:34 #22643
by Tom Z
deviationtx.com/forum/model-configs/1687...tings?start=20#22286
olongapso wrote: hi guys, thanks for models.
Last edit: 22 Apr 2014 00:34 by Tom Z.
- Tom Z
22 Apr 2014 00:54 #22645
by Tom Z
Hi, any of my Master CP models posted on this web site will work for your Airwolf 200SD3. But you must Reverse Elevator & Pitch. The Master CP and Airwolf 200SD3 have the same settings except for servo reverse.
Here is a model I just made for your Airwolf.
Download the model and rename it to model10 or whatever model number you want. Install it in your transmitter and your ready to fly. If you have a fixed ID from using the Walkera factory firmware clear it so it will bind with this deviation model.
FMOD = Normal mode for standard flying.
ST-1 & ST-2 modes are for 3D flying.
Replied by Tom Z on topic Beginner Settings
geyserbleu wrote: Good morning,
regard
- geyserbleu
22 Apr 2014 04:14 - 22 Apr 2014 04:21 #22649
by geyserbleu
Replied by geyserbleu on topic Walkera Master CP - Beginner Settings
Thanks a lot Tom Z. I will test your setting in this week end. I have to waiting for my piece, it was crashed on the first flight
because don't understand what is Fmod 1 2 3
But I remember that I switched Fmod in position 0 the heli can not fly or lift ( gas max ). Position 2 : It seem go down the ground, and Position 3 : in the midlle gas it fly but when I push the stick way up, it goes down immediately and crash
Excuse-me for my bad English. Any one speak French or Vietnamese ?
Have a nice day.
Have a nice day.
Last edit: 22 Apr 2014 04:21 by geyserbleu.
- Rio
07 Jun 2014 23:31 #23956
by Rio
Replied by Rio on topic Walkera Master CP - Beginner Settings
Sorry for the rookie question, but when you save or transfer this file to the transmitter(Devo 10). How do I select it?
- Tom Z
10 Jun 2014 03:17 #24008
by Tom Z
Model Setup - File - Load - Select the model you want, Press ENT to load.
See the Deviation User’s Manual for Devo7e/10 on Page 22 for pictures and more details.
- Sputnik
06 Jul 2014 14:37 #24421
by Sputnik
Replied by Sputnik on topic Walkera Master CP - Beginner Settings
Can someone post DEVO 10 settings for walkera QR X 350 pro
thanks
thanks
- Sputnik
06 Jul 2014 16:44 #24426
by Sputnik
This is my settings on DEVO 10 with 4.0.1 FW
And walkera QR X350 pro on 1.2 FW
name=QR X350
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=7
fixed_id=123456
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
subtrim=1
template=cyclic2
[channel2]
subtrim=1
template=cyclic1
[channel3]
safetyval=-110
subtrim=1
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=9
point
points=-100,-75,-50,-25,0,25,50,75,100
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=9
point
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=9
point
[channel4]
subtrim=1
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=0,0
[channel5]
subtrim=1
[channel6]
subtrim=1
template=cyclic3
[channel7]
subtrim=1
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=40
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX2
scalar=-100
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE2
curvetype=expo
points=0,0
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE2
curvetype=expo
points=0,0
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=!GEAR0
curvetype=9point
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=-1,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
src=Ch3
[datalog]
switch=AIL
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,
Ch3
Small-box=2,31,
Timer1
Small-box=2,40,
Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
name=QR X350
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=7
fixed_id=123456
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
subtrim=1
template=cyclic2
[channel2]
subtrim=1
template=cyclic1
[channel3]
safetyval=-110
subtrim=1
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=9
point
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=9
point
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=9
point
[channel4]
subtrim=1
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=0,0
[channel5]
subtrim=1
[channel6]
subtrim=1
template=cyclic3
[channel7]
subtrim=1
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=40
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX2
scalar=-100
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE2
curvetype=expo
points=0,0
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE2
curvetype=expo
points=0,0
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=!GEAR0
curvetype=9point
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=-1,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
src=Ch3
[datalog]
switch=AIL
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,
Ch3
Small-box=2,31,
Timer1
Small-box=2,40,
Timer2
Model=75,20
Battery=102,1
TxPower=102,7
- Sputnik
06 Jul 2014 16:45 #24427
by Sputnik
Can someone write some errors or ...?
06 Jul 2014 17:48 #24430
Replied by FDR on topic Walkera Master CP - Beginner Settings
It is unnecessary to use the cyclic mixers.
Use the sticks directly on Ch1 and 2, and no need for the Ch6 at all.
This is rather a CCPM 6channel heli config...
- Sputnik
06 Jul 2014 18:32 #24434
by Sputnik
Its really hard
I change it and nothing
Motor unlock code don`t working, GPS calibration same, none of command
06 Jul 2014 19:16 #24435
Start with the simple 4ch default plus a fixed value for the flight mode, and try the unlock functions.
If they don't work, try to increase the channel scale values...
- Sputnik
06 Jul 2014 19:46 #24436
by Sputnik
Where to change that?
06 Jul 2014 19:50 #24437
The first button with the cannel number and name, but there is a scale value on the mixer page too...
- Sputnik
06 Jul 2014 20:04 #24438
by Sputnik
Done that and nothing, no GPS calibration, no unlock motor no funktion at all
uh
uh
- Sputnik
06 Jul 2014 20:15 #24439
by Sputnik
Now is like this
name=QR X350
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=4
fixed_id=300952
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
scalar=115
scalar-=115
template=complex
[channel2]
scalar=115
scalar-=115
template=complex
[mixer]
src=AIL
dest=Ch2
usetrim=0
curvetype=expo
points=0,0
[channel3]
scalar=115
scalar-=115
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=0,0
[channel4]
scalar=115
scalar-=115
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=0,0
[channel6]
template=cyclic3
[channel7]
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=40
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX2
scalar=-100
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE2
curvetype=expo
points=0,0
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE2
curvetype=expo
points=0,0
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=!GEAR0
curvetype=9point
[trim1]
src=LEFT_V
pos=Up
neg=Down
[trim2]
src=RIGHT_V
pos=Up
neg=Down
[trim3]
src=LEFT_H
pos=TRIMLH+neg=TRIMLH-
value=-1,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=AUX4
pos=TRIM_L+
neg=TRIM_L-
[trim6]
src=AUX5
pos=TRIM_R+
neg=TRIM_R-
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
src=Ch3
[datalog]
switch=AIL
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
TxPower=102,7
name=QR X350
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=4
fixed_id=300952
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
scalar=115
scalar-=115
template=complex
[channel2]
scalar=115
scalar-=115
template=complex
[mixer]
src=AIL
dest=Ch2
usetrim=0
curvetype=expo
points=0,0
[channel3]
scalar=115
scalar-=115
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=0,0
[channel4]
scalar=115
scalar-=115
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=0,0
[channel6]
template=cyclic3
[channel7]
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=40
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX2
scalar=-100
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=FMODE2
curvetype=expo
points=0,0
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE1
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Virt2
switch=FMODE2
curvetype=expo
points=0,0
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=!GEAR0
curvetype=9point
[trim1]
src=LEFT_V
pos=Up
neg=Down
[trim2]
src=RIGHT_V
pos=Up
neg=Down
[trim3]
src=LEFT_H
value=-1,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=AUX4
pos=TRIM_L+
neg=TRIM_L-
[trim6]
src=AUX5
pos=TRIM_R+
neg=TRIM_R-
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
src=Ch3
[datalog]
switch=AIL
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
Time to create page: 0.487 seconds
Model Configs
- Walkera Master CP - Beginner Settings
