Walkera Master CP - Standard Settings
- Tom Z
07 Jan 2014 02:25 - 30 Apr 2014 15:17 #18121
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1 : V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Walkera Master CP - Standard Settings was created by Tom Z
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
Model 11 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 11-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 11 instead.
I have test flown this model in my Devo 10.
Throttle Curve
Pitch Curve
Gyro Gain
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:17 by Tom Z.
- Stavridis
18 Oct 2015 16:56 #39023
by Stavridis
Replied by Stavridis on topic Walkera Master CP - Standard Settings
Hi Tom!
What is the difference between 1st and 2nd .ini file?
- MarioCaxito
23 Oct 2016 16:23 #55311
by MarioCaxito
Replied by MarioCaxito on topic Walkera Master CP - Standard Settings
Hello friend, I'm picking up with the deviation. I can not set anything. I tried to follow the step without success. Could you please make a video programming the radio to the PC MASTER. Thank you.
Time to create page: 0.058 seconds
Model Configs
- Walkera Master CP - Standard Settings
