Blade 130 X - Beginner Settings
09 Jan 2014 13:17 - 15 Feb 2014 23:32 #18276 by Tom Z
Blade 130 X - Beginner Settings was created by Tom Z
* Re-posted 1/9/2014 - Accidentally deleted the other post while updating it.
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
  • Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
    If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
  • Lower Pitch Travel Adjustment to make the heli more tame.
  • Low dual rates and positive expo to tame the heli down.
  • Throttle hold on the RUDD D/R switch.
  • 7 Point Throttle and Pitch Curves.
  • TX Power=100mW
  • Channels=7
  • Protocol=DSMX
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 1 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Model 1-2 has Zero Degree Pitch when throttle hold is on.
    If you want control of the swash in TH to help you land in a crash don’t use this model use Model 1 instead.
    Model 22 is for deviation firmware v3 and the Devo 8/8S/12.
    Model 33 is for deviation firmware v3 and the Devo 10.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
Normal: 0% 40% 60% 68% 75%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +40%
0- AILE D/R = 50% EXP +40%
RUDD D/R = 80% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +40%
1- AILE D/R = 70% EXP +40%
Last edit: 15 Feb 2014 23:32 by Tom Z.
09 Jan 2014 21:39 - 09 Jan 2014 21:44 #18306 by Scott Bishop
Replied by Scott Bishop on topic Blade 130 X - Beginner Settings
Nice job, I like it better than the other one.
Fyi, it's getting the prompt on a 7e at start up that says:
Ch3 is 0%
safe value = -100%
Last edit: 09 Jan 2014 21:44 by Scott Bishop.
09 Jan 2014 23:22 - 10 Jan 2014 00:43 #18308 by Tom Z
Replied by Tom Z on topic Blade 130 X - Beginner Settings
Thanks.
I removed all the V4 models I posted and will correct that and re-post the models.
A line got doubled copied in the ini file and I need to remove it.
Last edit: 10 Jan 2014 00:43 by Tom Z.
10 Jan 2014 04:08 - 10 Jan 2014 05:00 #18314 by Tom Z
I fixed the Blade models that had the error message and they are now all re-posted. I had to correct a line in the .ini file.
I just added 7 point throttle and pitch curves to this model and all of my other my V4 models on this site.
Download the updated model and install it if you downloaded the model before that gave you the message: Ch3 is 0% safe value = -100%
If you do not get this message then you have the updated file.
Last edit: 10 Jan 2014 05:00 by Tom Z.
Time to create page: 0.119 seconds
