Align T-Rex 150 DFC - Standard Settings
- Tom Z
10 Jan 2014 17:06 - 22 Apr 2014 21:45 #18322
by Tom Z
Align T-Rex 150 DFC - Standard Settings was created by Tom Z
This model is for use with the Spektrum DSM2/DSMX Satellite Receiver.
NORM - 0% 30% 50% 55% 60%
ST- 1 - 90% 86% 84% 86% 90%
ST- 2 - 90% 86% 84% 86% 90%
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP +15%
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
- 7 Point Throttle and Pitch Curves
- Throttle hold on the RUDD D/R switch
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Model 21 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 21-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 21 instead.
Set your ESC Li-po Cell Count setting to "AUTO". Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to "Auto".
Do not use the "2S" setting. You will have an extreme power/headspeed loss using the default "2S" setting.
Pitch Curve
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
Switch Position
Switch Position
Last edit: 22 Apr 2014 21:45 by Tom Z.
- Waterfly
13 Feb 2014 22:43 #20245
by Waterfly
Replied by Waterfly on topic Align T-Rex 150 DFC - Standard Settings
Will this work with Devo 7E? Devo 7E has ST 1 only, not ST2.
- Tom Z
14 Feb 2014 01:38 #20249
by Tom Z
Replied by Tom Z on topic Align T-Rex 150 DFC - Standard Settings
The model will work on the Devo 7e but due to there is one less flight mode on that model you will not have all three flight modes FMOD0 - FMOD1 - FMOD2.
You will only have FMOD0 - FMOD1.
You will be OK with the Pitch and Throttle curves but I am not sure what will happen with the Gyro gain as the Devo 7e doesn't have a MIX switch which is what I assigned the gyro gains to.
One of the tech guys should be able to answer this when they see this post.
- micro
15 Feb 2014 14:25 - 15 Feb 2014 14:26 #20299
by micro
Replied by micro on topic Align T-Rex 150 DFC - Standard Settings
I have the model loaded and working on the dev07e but the heli wants to spin to the right as I try to lift off - no actual lift off as yet.
On V3 deviation I had access to pitch curves, dual rates and giro from the model menu, now I cannot see any of that and according to this setup vid I must change the curves to enter the setup of this heli as described in the manual p22 and this vidhttp://www.youtube.com/watch?v=wNvy-jB-PWQ&feature=youtu.be
Where is the curves and giro option in deviation 4 within this model now please?
Last edit: 15 Feb 2014 14:26 by micro.
- Tom Z
15 Feb 2014 15:00 - 15 Feb 2014 17:20 #20301
by Tom Z
Last edit: 15 Feb 2014 17:20 by Tom Z.
- Tom Z
15 Feb 2014 15:21 #20303
by Tom Z
I just updated the post above.
Also that video is for the factory firmware and not the deviation firmware.
With the deviation firmware you don't have to change any curves to enter setup for the helicopter.
- micro
15 Feb 2014 15:35 - 15 Feb 2014 15:41 #20304
by micro
Thanks Tom.
I am looking at it for a while and even have the manual but couldn't be less confident changing this stuff.
Why use an advanced mixer if it's only travel adjust, dual rates and expo that need changing along with some channel reversing? Still endlessly searching for a video to expain the algebra in the manual needed to use the advanced mixer. Why take away the normal use of curves instead of having both advanced mixer and basic setup like normal tx? Can't we have both enabled?
Can I switch it back to normal mixing and actually have standard curves like v3 had?
Do you have a dev07e to test on as one wrong move and the trex 150 will be toast at that headspeed, just feel like it wants to spin.
Last edit: 15 Feb 2014 15:41 by micro.
- Tom Z
15 Feb 2014 16:09 - 15 Feb 2014 16:54 #20306
by Tom Z
Your welcome.
Standard mixer mode is too limited for the models and all the options I want to use so I have to use advanced mixer which takes some time to figure out and learn.
This is VERY important. You can't change a model made in advanced mixer to standard mixer. I have tried it. First it will reset the model (erase settings) but it also keeps some on the settings and changes other settings.
I posted a model before and after my model was switched from advanced mixer to standard mixer to show what happens.
deviationtx.com/forum/3-feedback-questio...x-deviation-8s#19469
Last edit: 15 Feb 2014 16:54 by Tom Z.
- Tom Z
15 Feb 2014 16:53 - 17 Feb 2014 21:56 #20309
by Tom Z
It sounds like your gyro gain is not high enough.
I changed the gyro value to 75% and it is now assigned to the FMOD switch.
FMODE0 and FMODE1 are 75% gyro gain.
The 75% value is the most used value on the internet for this model which is why I set it to the value.
You can try this out if you want and see if the tail now holds which it should.
Just try to lift off (don't try to hover or fly) like you did before and see if the tail now holds.
Edit: Model deleted
Edit: Model deleted
Last edit: 17 Feb 2014 21:56 by Tom Z.
- micro
16 Feb 2014 13:54 #20355
by micro
Thank you very much for making the giro adjusted model TomZ.
I read the thread you linked about chaging the advanced mixer to standard and that 'limits' need resetting before it will work for the idle up pitch curves. Where is this limit setting please.
I will try your model asap in a couple hours when back home but If I can swap the advanced models back to simple I will have no problem setting up the rest of the heli once channels outputs are correct.
I'd also like to be able to tweak it easily to experiment for myself if possible. Thanks again, feeling close..
- Tom Z
16 Feb 2014 15:11 #20358
by Tom Z
Your welcome.
You can't switch a model from advanced to standard. It doesn't clear the settings as it says it will but what it does is keep some settings and change most of them and does a lot of things it shouldn't do like adding virtual channels which it shouldn't, assigns incorrect values, changes switch assignments to the wrong ones, reverses things it shouldn't, changes 7 point curves to 9 point curves, incorrectly changes channel assignments, and other some things...
I posted those models to show what happens if you switch from advanced to standard mixer mode. This is a bug and it has been reported. Changing a model from advanced to standard is made to clear (erase) all the settings 100% and it doesn't.
The 7e model I made should work good and you can fine tune the gyro gain and DR/EXPO settings.
- micro
16 Feb 2014 15:25 - 16 Feb 2014 15:44 #20360
by micro
Ok, I get a hover with tail behaving with the last .ini you uploaded so huge thanks again.
I only tried normal mode as inside in a very small space but found it way too soft to be flyable, no authority at all. I enter the mixer and see high rate set to 70% with 30% expo but then a mid rate below that is linked but set to 100%. I can't even figure out where to see my travel adjust. The heli looks like it has about 2 degreees of pitch only.
There's also scales?
Why is hold1 listed as my switch if this is TH.
Please has someone made a simple model, this lack of converting files back and forth is THE reason it's so difficult to transition or even learn how the advanced mixer works. I read PB reply as he understood the issues at first but he was just refering to the last issue mentioned in that thread. I tried the switch to simple and only found pitch curves for idle up missing, the screen that is, not just the entries. Obviously I missed the other stuff
Is the only way to copy a model to do within the usb windows interface and rename stuff? Couldn't find anything in the manual or tx for this.
Last edit: 16 Feb 2014 15:44 by micro.
- Tom Z
16 Feb 2014 15:52 #20362
by Tom Z
That's good the tail now holds!
Advanced mixer mode is complex and confusing to learn. It took me a while to figure it out using the emulator and trial and error of testing the model in my helicopters and quads.
Your Devo 7e will use hold1 for TH so that is correct.
I set TR to Rudder DR Switch on Position 1 for the model which I made with my Devo 10.
If you use the model on the Devo 7e or Devo 12 the TH will change to hold1.
The models I make on this site must be made in advanced mixer mode for the complex settings I want to use.
I would not try to use my models if you change it to standard mode.
Even though you found pitch curves for idle up missing, all the other settings, channel assignments, switch assignments and other things must be correct. There should also be no virtual channels either.
Trying to fly this way could cause the heli to freak out in flight and crash.
I can change the DR/EXPO for you very fast and easy and post the model for you. What settings would you like?
- micro
16 Feb 2014 16:10 - 16 Feb 2014 16:53 #20363
by micro
I would be after full rates, and I can guess about 30% expo, positive.
Were the settings you entered really the ones in Alan's vid and the manual?
Should I expect a jump in pitch when I switch to idle up?
Alan's vid
If you could tell me the channels to reverse I can do that but is it even possible to switch the output channels like I think is needed for this heli in simple mode at all?
Alan's vid
Last edit: 16 Feb 2014 16:53 by micro.
- Tom Z
16 Feb 2014 16:56 - 17 Feb 2014 21:57 #20369
by Tom Z
Here you go.
DR/EXPO
Yes there will be a height change switching between flight modes.
I make some 3D models with no height change switching between flight modes.
The headspeed in normal mode is 100% at mid stick and matches the headspeed on Idle up modes. The headspeed at 100% in normal mode is wicked fast and is not good for beginners and most other non 3D people so I don't make all the models this way. I can for you if you want.
I haven't seen Alan's video so I don't know what settings he used.
Edit: Model deleted
DR/EXPO
Edit: Model deleted
Last edit: 17 Feb 2014 21:57 by Tom Z.
- Tom Z
16 Feb 2014 17:01 #20370
by Tom Z
See my Align T-Rex 150 DFC Transmitter setup guide on my web site.
This will give you all the settings.
www.rcproreviews.com/align-t-rex-150-dfc...eginner-3d-settings/
I use all of my transmitter setup guides to make the deviation models then tweak them if needed and also convert the values as needed.
See my Tutorial here:
Converting deVention values to deviation values
deviationtx.com/forum/how-to/2620-conver...-to-deviation-values
- micro
16 Feb 2014 17:10 #20374
by micro
Alan's vid
Is it possible to set this heli up with the 7e using deviation firmware ONLY in simple mode?
Do I need to reverse channels and assign channel outputs or just reverse channels?
Daylight is now gone for the day so no rush.
- Tom Z
16 Feb 2014 17:13 #20375
by Tom Z
micro wrote: Alan's vid
Is it possible to set this heli up with the 7e using deviation firmware ONLY in simple mode? Yes
Do I need to reverse channels - Yes
and assign channel outputs - Not sure. I have used simple mode.
- micro
16 Feb 2014 17:28 #20377
by micro
It is not in simple mode when I try your model on my tx but you say you use simple mode to make the model?
- Tom Z
16 Feb 2014 18:14 #20383
by Tom Z
No I have never used standard mixer mode to make any models. All my models are made using advanced mixer mode.
Due to all the confusion and I know you really need this model in standard mixer mode I just made a model for you from scratch using the standard mixer.
You can install it and fly.
I will post the model soon as I am double checking everything...
micro wrote: It is not in simple mode when I try your model on my tx but you say you use simple mode to make the model?
Time to create page: 0.959 seconds
Model Configs
- Align T-Rex 150 DFC - Standard Settings
