Walkera V200D03 - Beginner Settings
- Tom Z
13 Jan 2014 03:57 - 30 Apr 2014 15:19 #18457
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
62% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 75% gyro gain.
DR/EXPO
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Walkera V200D03 - Beginner Settings was created by Tom Z
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Lower Pitch Travel Adjustment to make the heli more tame.
- Low dual rates and positive expo to tame the heli down.
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
Model 23 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 23-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 23 instead.
Throttle Curve
Pitch Curve
Gyro Gain
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:19 by Tom Z.
Time to create page: 0.214 seconds
Model Configs
- Walkera V200D03 - Beginner Settings
