Blade FP Helicopter - Beginner Settings
- Tom Z
14 Jan 2014 01:08 - 15 Feb 2014 23:33 #18491
by Tom Z
Blade FP Helicopter - Beginner Settings was created by Tom Z
This model will work on the following helicopters.
- Blade SR 120
- Blade mSR/mSR-X
- Blade mCX/mCX2
- Low dual rates and positive expo to tame the heli down.
- Throttle hold on the RUDD D/R switch.
- TX Power=100mW
- Protocol=DSMX
- No Fixed ID
Model 25 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Flight Mode switch on "0" = Helicopter will be tamer, soft throttle response
Flight Mode switch on "1" = More responsive, normal throttle response
Flight Mode switch on "2" = More responsive, normal throttle response
Channel 5 affects rate settings of the 5-in-1 Control Unit.
Use the Gear switch to switch between high and low rate.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Last edit: 15 Feb 2014 23:33 by Tom Z.
Time to create page: 0.090 seconds
Model Configs
- Blade FP Helicopter - Beginner Settings
