Blade FP Helicopters - Standard Settings
14 Jan 2014 01:10 - 15 Feb 2014 23:34 #18492 by Tom Z
This model will work on the following helicopters.
  • Blade SR 120
  • Blade mSR/mSR-X
  • Blade mCX/mCX2
  • Throttle hold on the RUDD D/R switch
  • TX Power=100mW
  • Protocol=DSMX
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 26 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Flight Mode switch on "0" = Helicopter will be tamer, soft throttle response
    Flight Mode switch on "1" = More responsive, normal throttle response
    Flight Mode switch on "2" = More responsive, normal throttle response
    Channel 5 affects rate settings of the 5-in-1 Control Unit.
    Use the Gear switch to switch between high and low rate.
    DR/EXPO
    Switch Position
    0- ELEV D/R = 70% EXP +30%
    0- AILE D/R = 70% EXP +30%
    RUDD D/R = 100% EXP LIN
    Switch Position
    1- ELEV D/R = 100% EXP LIN
    1- AILE D/R = 100% EXP LIN
    If the tail is too touchy for you add some positive expo.
    Try +20%. EX: RUDD D/R = 100% EXP +20%
Last edit: 15 Feb 2014 23:34 by Tom Z.
Time to create page: 1.473 seconds
