Walkera V100D01 - Standard Settings
- Tom Z
21 Jan 2014 23:40 - 30 Apr 2014 15:24 #18884
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Walkera V100D01 - Standard Settings was created by Tom Z
- Protocol=WK2401
- TX Power=100mW
- No Fixed ID
- Throttle Hold is active on RUDD D/R switch.
Model 30 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:24 by Tom Z.
Model Configs
- Walkera V100D01 - Standard Settings
