Walkera 4F200LM - Standard Settings
- Tom Z
23 Jan 2014 02:45 - 30 Apr 2014 15:19 #18966
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
Set to 75% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 50% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Walkera 4F200LM - Standard Settings was created by Tom Z
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
Model 32 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 32-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use
this model use Model 24 instead.
Throttle Curve
Pitch Curve
Gyro Gain
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:19 by Tom Z.
- Rkozak99
29 Jan 2014 01:23 #19354
by Rkozak99
Replied by Rkozak99 on topic Walkera 4F200LM - Standard Settings
These setting use the Advanced GUI. Can they be reset to you the Standard GUI?
- Tom Z
29 Jan 2014 01:38 #19355
by Tom Z
Replied by Tom Z on topic Walkera 4F200LM - Standard Settings
If you change the Advanced GUI to Standard GUI it will reset the model
which will erase all of my settings.
Time to create page: 0.887 seconds
Model Configs
- Walkera 4F200LM - Standard Settings
