Walkera CP Helicopters - 3D Settings
27 Feb 2014 17:22 #20929 by bandituk1
Replied by bandituk1 on topic Walkera CP Helicopters - 3D Settings
Hi all do any of these configs work on the devo 7E with a mini cp?
Dave
27 Feb 2014 23:06 - 27 Feb 2014 23:16 #20940 by Tom Z
Replied by Tom Z on topic Walkera CP Helicopters - 3D Settings
You can use the model in your Devo 7e. My custom GUI in the model file is also made to use with the 7e.
The issue is that the 7e has less switches. So you will only have one stunt mode plus you will not have DR/EXPO 1 and 2.
Here are the DR/EXPO settings and switches I have set:
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -10%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
If you use the model on your 7e you will only have one DR/EXPO position
and only one stunt mode.
I think this is what you will have.
DR/EXPO
Stunt Mode: V Shaped Throttle Curve
Stunt Mode: Full +/- 3D pitch curve. Zero degrees pitch at mid stick.
If you are OK with these settings then you should be able to use my model on your 7e.
You can always adjust the stunt mode settings and DR/EXPO to what you like.
Last edit: 27 Feb 2014 23:16 by Tom Z.
28 Feb 2014 09:22 #20951 by bandituk1
Thanks Tom
Just what I needed
Dave
08 Dec 2014 21:07 #26856 by olongapso
Replied by olongapso on topic Walkera CP Helicopters - 3D Settings
hi guys, how much sensitivity have you on your master cp receiver?
I stay at 2/5 of range but I am not confident to try 3d figures.
04 Mar 2015 02:59 #29307 by ricardo_amaral79
Replied by ricardo_amaral79 on topic Walkera CP Helicopters - 3D Settings
I am trying to use your settings on my Devo 7e, but my trottle is as follows: at 0% the engine is off by 50% it is practically a maximum of 100% and he practically, is turning slowly ... someone can help me troubleshoot? thank you
25 Mar 2017 08:11 #60717 by bryanlorenzo79
Replied by bryanlorenzo79 on topic Walkera CP Helicopters - 3D Settings
Hi
Im new to deviation. im just wondering what the 7th channel is for on your model.ini. Thanks
25 Mar 2017 10:10 #60722 by FDR
Replied by FDR on topic Walkera CP Helicopters - 3D Settings
That is the gyro on the DEVO models.
25 Mar 2017 10:20 #60724 by bryanlorenzo79
Thanks FDR. is it just an on/off thing? i just downloaded a model for v120d02s here and theres nothing on channel 5(HOLD) but there is a Safety<HOLD1> on channel 3-THR. is that a coventional way of setting it up? Thanks again
25 Mar 2017 11:54 #60726 by FDR
Not necessarily on/off, but perhaps some switchable value which give more or less stabilization, but it might be one constant as well.
Ch3 is throttle, that's why is has the safety value, aka throttle hold.
26 Mar 2017 03:18 #60754 by bryanlorenzo79
Thanks. I think the channel 7 is the gyro for the tail only. I had the setting to "0" on the scale and the v120 just spins. when i had it all the way up (like 125) the tail was wagging. I guess too much gyro compensation? when i had it around "50" the tail is solid! Good to know!
