Align T-Rex 150 DFC - Ultra Beginner Settings
- Tom Z
31 Jan 2014 16:23 - 22 Apr 2014 21:46 #19507
by Tom Z
Align T-Rex 150 DFC - Ultra Beginner Settings was created by Tom Z
This model is different than my Beginner Settings model posted on this web site. It is even tamer and will hover at about 1 line above the half stick throttle mark. I made this model for the beginner who is flying a CP helicopter for the first time. This model is made just to hover and fly around.
Normal: No negative pitch at low stick. Hover at about 1 line above the half stick throttle mark.
ST-1: Same as Normal Mode.
ST-2: -3* negative pitch so you can fly in wind if you want to. It will hover about 1 line above the half stick throttle mark.
You can also use this mode to get use to having negative pitch at low stick.
I left out full +/- Stunt modes as a beginner will not use them. Also there is no chance of accidentally selecting full +/- pitch.
Throttle Curve
Normal: Linear Curve
ST-1: Linear Curve
ST-2: Linear Curve
Pitch Curve
Normal: No negative pitch. Helicopter will hover about 1 line above the half stick throttle mark.
ST-2: -2* negative pitch. Helicopter will hover about 1 line above half the stick throttle mark.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO - ELEV, AILE, RUDD are all the the AILE switch for quick and easy changing in hover or flight.
Don't try to flip or 3D with these settings.
Switch Position - This setting is for hovering and slow forward flight only.
0- ELEV D/R = 30% EXP -10%
0- AILE D/R = 30% EXP -10%
RUDD D/R = 100% EXP +20%
Switch Position
1- ELEV D/R = 50% EXP +30%
1- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Very Low Pitch to make the heli more tame.
- Hover at about 1 line above the half stick throttle mark. This is helpful for beginners to learn on.
- Low Dual Rates and Expo to tame the heli down.
- Throttle Hold on the RUDD D/R switch.
Zero Degree Pitch when throttle hold is on.
This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike. - 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
If you fly outside in wind use ST- 2 which has negative pitch which can pull the heli down in wind.
EDIT: 2/19/2014
This model has been updated. The pitch was raised as it wasn't hovering at mid stick and needed more than half throttle to hover.
Model 40 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Set your ESC Li-po Cell Count setting to "AUTO". Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to "Auto".
Do not use the "2S" setting. You will have an extreme power/headspeed loss using the default "2S" setting.
Throttle Curve
ST-1: Linear Curve
ST-2: Linear Curve
Pitch Curve
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
Switch Position
Last edit: 22 Apr 2014 21:46 by Tom Z.
- Tom Z
23 Feb 2014 23:41 #20818
by Tom Z
Replied by Tom Z on topic Align T-Rex 150 DFC - Ultra Beginner Settings
Model updated.
I just found out the Align manual was incorrect on the gyro values.
The model first posted gyro settings were:
Mix Switch
Pos 0: 55%
Pos 1: 65%
Pos 2: 75%
Updated model gyro settings are now:
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
70% to 75% is the most common values used on the internet. Fine tune the gyro gain to meet your needs.
Mix Switch
Pos 0: 55%
Pos 1: 65%
Pos 2: 75%
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
Time to create page: 0.025 seconds
Model Configs
- Align T-Rex 150 DFC - Ultra Beginner Settings
