Nine Eagles Solo Pro 180 3D - Beginner Settings
- Tom Z
01 Feb 2014 16:57 - 15 Feb 2014 23:38 #19599
by Tom Z
Nine Eagles Solo Pro 180 3D - Beginner Settings was created by Tom Z
Nine Eagles Solo Pro 180 3D (318A)
This model was started by ave1 and I added the rest of the settings needed. ave1 test flew the model with good results.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: V Shaped Throttle Curve
ST-2: V Shaped Throttle Curve
Pitch Curve
Normal: No negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Throttle Hold on the RUDD D/R switch.
Zero Degree Pitch when throttle hold is on.
This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike. - 7 Point Throttle and Pitch Curves
- Low dual rates and positive expo to tame the heli down
- Throttle hold on the RUDD D/R switch
- TX Power=100mW
- Channels=7
- Protocol=J6Pro
- No Fixed ID
If you fly outside in wind use ST-1 or ST-2 which have full pitch curves which can pull the heli down in wind.
Model 41 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Throttle Curve
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:38 by Tom Z.
- Tom Z
04 Feb 2014 05:57 #19816
by Tom Z
Replied by Tom Z on topic Solo Pro 180 - Beginner Settings
I changed the 5 point throttle and pitch curves to 7 point throttle and pitch curves.
I removed the Gyro gain from the MIX switch. It had three gyro gain settings 25% - 50% - 75%. The 50% setting turned out to be adjustment mode (gyro gain off).
If you were to hit the MIX switch by mistake in flight to the 50% setting the helicopter would spin on you so I removed the 50% setting and assigned the Gyro gain to the Gear switch.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Here is what the MIX settings were.
Gyro Gain
Mix Switch
Pos 0: 25%
Pos 1: 50%
Pos 2: 75%
All the values above were then converted to the deviation values.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Gyro Gain
Mix Switch
Pos 0: 25%
Pos 1: 50%
Pos 2: 75%
Time to create page: 0.507 seconds
Model Configs
- Nine Eagles Solo Pro 180 3D - Beginner Settings
