Nine Eagles Solo Pro 180 3D - Standard Settings
- Tom Z
01 Feb 2014 16:59 - 15 Feb 2014 23:38 #19600
by Tom Z
Nine Eagles Solo Pro 180 3D - Standard Settings was created by Tom Z
Nine Eagles Solo Pro 180 3D (318A)
This model was started by ave1 and I added the rest of the settings needed. ave1 test flew the model with good results.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: V Shaped Throttle Curve
ST-2: V Shaped Throttle Curve
Pitch Curve
Normal: -3* negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
- Low dual rates and positive expo to tame the heli down
- Throttle hold on the RUDD D/R switch
- 7 Point Throttle and Pitch Curves
- TX Power=100mW
- Channels=7
- Protocol=J6Pro
- No Fixed ID
Model 42 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Throttle Curve
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:38 by Tom Z.
- Tom Z
04 Feb 2014 06:00 #19818
by Tom Z
Replied by Tom Z on topic Solo Pro 180 - Standard Settings
Update:
I changed the 5 point throttle and pitch curves to 7 point throttle and pitch curves.
I removed the Gyro gain from the MIX switch. It had three gyro gain settings 25% - 50% - 75%. The 50% setting turned out to be adjustment mode (gyro gain off).
If you were to hit the MIX switch by mistake in flight to the 50% setting the helicopter would spin on you so I removed the 50% setting and assigned the Gyro gain to the Gear switch.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Here is what the MIX settings were.
Gyro Gain
Mix Switch
Pos 0: 25%
Pos 1: 50%
Pos 2: 75%
All the values above were then converted to the deviation values.
Gear Switch
Pos 0: 25%
Pos 1: 75%
Gyro Gain
Mix Switch
Pos 0: 25%
Pos 1: 50%
Pos 2: 75%
Time to create page: 0.100 seconds
Model Configs
- Nine Eagles Solo Pro 180 3D - Standard Settings
