- Phoenix configs for devo-10 using deviation 4.0.1
- Hondawasaki
01 Feb 2014 21:15 - 02 Feb 2014 11:45 #19627
by Hondawasaki
Phoenix configs for devo-10 using deviation 4.0.1 was created by Hondawasaki
Does anyone have a working setup that they are willing to share?
as the title states I need a config for devo10 using deviation4.0.1 on Phoenix rc 4 ... so far the only one I've found is for
deviation 3
please help me
if no one has a setup . what do i need to change from the dev 3 version so it will work for dev4 ?.. If I can get it to work correctly I will definitely share my settings for others
deviation 3
please help me
Last edit: 02 Feb 2014 11:45 by Hondawasaki.
- malc
06 Feb 2014 18:00 #19938
by malc
Replied by malc on topic Phoenix configs for devo-10 using deviation 4.0.1
- Hondawasaki
08 Feb 2014 22:44 #20006
by Hondawasaki
Replied by Hondawasaki on topic Phoenix configs for devo-10 using deviation 4.0.1
Thanks I'll give that a try asap ... currently using my tx @ friends house and copy of Phoenix .
Plan to get my own copy soon.
- Hondawasaki
12 Mar 2014 18:50 #21506
by Hondawasaki
this is working for me but no switches
- Hondawasaki
15 Mar 2014 05:37 #21559
by Hondawasaki
Fixed all working .....
.Hondawasaki wrote: Does anyone have a working setup that they are willing to share?
deviation 3
please help meif no one has a setup . what do i need to change from the dev 3 version so it will work for dev4 ?.. If I can get it to work correctly I will definitely share my settings for others
- Teemu147
07 Jun 2014 14:02 #23950
by Teemu147
Replied by Teemu147 on topic Phoenix configs for devo-10 using deviation 4.0.1
Can I set tx power to minimum or zero when using simulator? Currently i have 150mW and it draind lots battery.
07 Jun 2014 20:33 #23954
Replied by FDR on topic Phoenix configs for devo-10 using deviation 4.0.1
When you use the PPM protocol, it turns off the RF transmition...
- fl0w
24 Jul 2014 17:02 #24776
by fl0w
Replied by fl0w on topic Phoenix configs for devo-10 using deviation 4.0.1
I'm using my devo-10 with deviation 4.0.1 in Phoenix 5. I used the ini file you uploaded. I have an issue with the channel 3 which is assigned to the gaz function. It looks like it doesn't behave like a gimbal but more like a switch. When it's full down, it shows 0 in Phoenix. When I start moving it upward, it remains to 0 but when I reach 30/40 % it moves suddently to 100% in Phoenix. There is no "in between".
I switch the gaz command to channel 8. It's better but i'm wondering why it reacts like this.
Do you have any ideas ?
- a178235
24 Jul 2014 17:47 - 24 Jul 2014 17:55 #24777
by a178235
Replied by a178235 on topic Phoenix configs for devo-10 using deviation 4.0.1
I tested my DEVO-10 with PhoenixRC 5.0 last night and the attached files is what I used and it worked.
C:\Users\Username\Documents\PhoenixRC\Settings\mappingProfiles\Custom\Walkera_DEVO-10.pcx
1-Elevator
2-Aileron
3-Throttle
4-Ruder
5-Gear Swith
6-F-Mode Switch
7-Mix Switch
8-Rudder D/R Switch (Throttle Hold)
Number Pad 4-Low Rates
Note: Center F-Mode & Mix Switches Before Calibration!
1-Elevator
2-Aileron
3-Throttle
4-Ruder
5-Gear Swith
6-F-Mode Switch
7-Mix Switch
Last edit: 24 Jul 2014 17:55 by a178235.
- fl0w
24 Jul 2014 17:55 #24778
by fl0w
I'll try it tonight. I'll keep you posted.
Time to create page: 0.206 seconds
Model Configs
