Blade NanoCPX/130X - Ultra Beginner Settings
- Tom Z
02 Feb 2014 01:36 - 20 Feb 2014 17:19 #19666
by Tom Z
Blade NanoCPX/130X - Ultra Beginner Settings was created by Tom Z
This model is different than my Beginner Settings model posted on this web site. It is even tamer and will hover at about 1 line above the half stick throttle mark. I made this model for the beginner who is flying a CP helicopter for the first time. This model is made just to hover and fly around.
This model is for the Blade Nano CP X and Blade 130 X.
Normal: No negative pitch at low stick. Hover at about 1 line above the half stick throttle mark.
ST-1: Same as Normal Mode.
ST-2: -3* negative pitch so you can fly in wind if you want to. It will hover about 1 line above the half stick throttle mark.
You can also use this mode to get use to having negative pitch at low stick.
I left out full +/- Stunt modes as a beginner will not use them. Also there is no chance of accidentally selecting full +/- pitch.
Throttle Curve
Normal: Custom Curve
ST-1: Custom Curve
ST-2: Custom Curve
Pitch Curve
Normal: No negative pitch. Helicopter will hover about 1 line above the half stick throttle mark.
ST-2: -2* negative pitch. Helicopter will hover about 1 line above half the stick throttle mark.
DR/EXPO - ELEV, AILE, RUDD are all the the AILE switch for quick and easy changing in hover or flight.
Don't try to flip or 3D with these settings.
Switch Position - This setting is for hovering and slow forward flight only.
0- ELEV D/R = 30% EXP -10%
0- AILE D/R = 30% EXP -10%
RUDD D/R = 100% EXP +20%
Switch Position
1- ELEV D/R = 50% EXP +30%
1- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Very Low Pitch to make the heli more tame.
- Hover at about 1 line above the half stick throttle mark. This is helpful for beginners to learn on.
- Low Dual Rates and Expo to tame the heli down.
- Throttle Hold on the RUDD D/R switch.
Zero Degree Pitch when throttle hold is on.
This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike. - 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
If you fly outside in wind use ST- 2 which has negative pitch which can pull the heli down in wind.
EDIT: 2/19/2014
This model has been updated. The pitch was raised as it wasn't hovering at mid stick and needed more than half throttle to hover.
Model 44 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Throttle Curve
ST-1: Custom Curve
ST-2: Custom Curve
Pitch Curve
Switch Position
Last edit: 20 Feb 2014 17:19 by Tom Z.
- Hondawasaki
19 Feb 2014 17:44 #20590
by Hondawasaki
Replied by Hondawasaki on topic Blade NanoCPX/130X - Ultra Beginner Settings
lol I tried this one and no hover at all ... needs more than ,50
Im using a Bnew Blade nano cpx .
- Tom Z
19 Feb 2014 19:28 - 20 Feb 2014 05:55 #20600
by Tom Z
Replied by Tom Z on topic Blade NanoCPX/130X - Ultra Beginner Settings
I raised the pitch at mid stick. Try it out.
It should now hover at about 1 line past half throttle.
Last edit: 20 Feb 2014 05:55 by Tom Z.
- Hondawasaki
21 Feb 2014 17:21 #20701
by Hondawasaki
I will give it a try soon ... when i tried it before i discovered that there was 0 collective input ... so I was like wow this is ultra beginner lol
- Hondawasaki
21 Feb 2014 17:36 #20702
by Hondawasaki
ok i tested the fixed file and it is working .....i get lift off but not to aggressive for new pilots. and see that the file has head lock with TH on.
Thanks Tom z
Thanks Tom z
- Tom Z
21 Feb 2014 18:54 - 21 Feb 2014 23:36 #20707
by Tom Z
Your welcome.
Thanks for testing the model for me!
There is 0 collective on the on the lower pitch points which eliminate any negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
Here are a couple of examples for Walkera.
Pitch - Normal Mode: 0% 0% 0% 50% 100%
Hover about 1 line above the half stick throttle mark.
Pitch - Normal Mode: 0% 0% 20% 50% 100%
* You might need more than 20% to hover. The varies between helicopters.
For the Walkera Devo Transmitter 0% = Zero pitch.
For the Walkera 2801 Pro Transmitter 50% = Zero pitch.
For the Blade Transmitter 50% = Zero pitch.
Last edit: 21 Feb 2014 23:36 by Tom Z.
- norris
31 May 2016 17:44 #49659
by norris
Replied by norris on topic Blade NanoCPX/130X - Ultra Beginner Settings
Which version works with Deviation 5 and Devo7e?
Time to create page: 0.199 seconds
Model Configs
- Blade NanoCPX/130X - Ultra Beginner Settings
